Question about Denon Audio Players & Recorders
No output on 1 speaker, when turning volume up I get a ticking sound which disrupts the playing of CD. I have tried disconnecting speakers and reconnecting, both speakers are working but when connected together sound only comes out of 1.
  • randhillon Oct 31, 2008
    the ticking sound is coming from the AMP when volume is turned up even sligtly. When you say something is touching along the line what do you mean?
  • randhillon Nov 18, 2008
    Thank you for the advice, it worked, I have music again!
  • 86 Answers
Is the ticking sound comming from the receiver? if it is then that speaker is either damage or theres somthing touching along the line, either in the box or out of the box running to the receiver, or one of your channels may of shorted out
Posted on Oct 30, 2008
  • Ivan Mcdean
    Ivan Mcdean Nov 12, 2008
    along the line meaning, some where in the wiring somthings touching from the speaker to the reciver, or inside the box thats rare on some cases but still could check, an or if you would have spiced the wires to make it longer you could check that, an on the back of the receiver check the terminals for a wire that could connect the positive to the negitive witch would also cause a ticking sound, even the speaker box terminals. Hope that helps
Konzert amplifier has a problem with the audio, it goes on and off how to fix it?
if the relay keeps ticking it certainly means the relay senses an overload or a short circuit in the outputs(speakers). pls. check your speakers, tweeters connection. if you have another amplifier try your speakers if it will be working fine. be sure your speaker wires donot touch each other. try playing at low volumes settings.
May 30, 2013 | Audio Players & Recorders
Everytime i try to play my system at full volume it cuts out then keeps playing and carries on doing this to i turn it to a certain volume
First of all find out the recommended speaker impedance for the receiver. Then find out the impedance of the speakers you are using along with it.
Simple rule is the speaker impedance can be higher but not lower than the recommended value. If it is so the receiver will run hot and if you turn up the volume higher it will run even hotter and then the protection circuit will cut off the Amplifier output to prevent burn out of components. Even if you have one defective speaker this cut off can happen. To confirm defective speaker -- disconnect one speaker at a time and turn on the amplifier and play it at cut off volumes.If by disconnecting one particular speaker the Amplifier does not cut off -- THAT SPEAKER HAS A SHORTED COIL and needs replacement.
Apr 03, 2011 | Philips Audio Players & Recorders
I have a Onkya TX 910 receiver that has recently started malfunctioning. It is currently hooked up to one speaker and it is putting out very little sound (as if it is on a low output but it is turned all...
Turn the volume down to about 1/4. If you can't hear it there it isn't going to suddenly appear at higher volumes. Never troubleshoot anything with the volume at or near maximum.
Look for a mispositioned Mute or tape Monitor control.
Jan 18, 2011 | Onkyo Audio Players & Recorders
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
Emachines 180 desktop sound problems
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those
Sep 21, 2009 | E-Machines eMachines Desktop PC
Hi, I can no longer get voices when I play my movies on dvd player, but there is sound, what button did my son inadvertently push!
Either he has turned on your Mute or he has changed your Audio Output. Check your Setup Menu under Audio and make sure that it has been set to output to either your TV or your stereo, depending on which source you normally use.
Sep 14, 2009 | Televison & Video
No sound from speakers on acer 6706 desktop
First check you dont have a red line through your speaker on your toolbar. If so click it and "UN-mute it.
Check that the speakers are plugged into the GREEN port on the back of the computer and that the speakers are powered up with the volume at about 1/2 way.
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left)
Click PROERTIES
Make sure that Volume controls, Wave, SW Synth, CD PLayer, Line IN, and MIC all show on there and that the volume sliders are about half way up.
Make sure noe of the sliders have ticks at the bottom, if so UNTICK them.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else unles you know you want that item)
If not double check that you have no problems with your hardware from the device manager.
Sep 07, 2009 | Acer Veriton 5600G PC Desktop
I cant get sound on my computer
Click PROERTIES
Sep 06, 2009 | Acer Audio Players & Recorders
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
Sound gone
disconnect everything in the back of the unit. reconnect only the cd to the imputs. also,just to be sure, disconnect all speakers(label them). fire it up,play a CD, connect the speakers 1 at a time. If the 1st works you have hope ,if not, try each channel individualy.The one that reduces volume is the problem-maybe shorted cable, bad speaker,or , God forbid-Bad amp Channel. good luck
Dec 30, 2007 | Yamaha R-V1103 Receiver
132 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
