Question about Panasonic CT-32HL43 32" TV
TV will not turn on
The TV will not turn on by using the remote or by pressing the power button on the TV. It had been used earlier in the day and was fine, and was turned off by the remote. I checked all the plugs and cable wires. Any thoughts?
  • Anonymous Mar 23, 2014
    My magnavox tv power button is broken and the tv is turned off by the digital remote.One of the buttons wasn't working on the remote so I exchanged it with the cable company. I now have a new remote and cannot turn the tv on.
    Sergeant:
  • 337 Answers
Should unplug the unit from the outlet first then after 5 minutes plug it back in,if this does not work it most likely needs service specially if you lost complete power in the house or if it was raining with lightning.
Posted on Sep 12, 2006
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Previously Requested but no solution: I cannot reprogram the remote for this TV so that I can connect to AT&T Uverse Satellite. I do not have a mdoel number for the TV remote that came with the...
Hello, Mr. Ross.
I'll be more than happy to assist you with this and all of your other Uverse concerns.
First please write these codes down, these are the TV codes for your Mitsubishi TV,
0093, 0150, 0178, 0019 (we are going to do trial and error for these codes till we hit the correct one for your TV.)
Please turn the TV on and point your ATT remote control.
Okay, using your ATT remote control, please press and hold the TV button together with the "OK" button.
All four modes should flash twice indicating that we are programming your remote control.
Now, enter the 4 digit code and the selected mode (in our case it is the TV) should give a long flash.
Then press OK.
Try to turn your TV off and check if it would respond
If not, please redo the steps but this time use the other codes I provided earlier.
If these codes wont work we will do the automatic code finder if you are using the "black" AT&T Uverse remote control.
Using your ATT remote control, please press and hold the TV button together with the "OK" button.
Then press the "scan/ff" button repeatedly with atleast 1 second interval till it turns your TV off.
Press OK then try to turn your TV on again.
Whenever your remote won't respond, try pressing either the AT&T button on top of the remote before any other buttons or the TV button beside the ATT button.
Aug 10, 2011 | Mitsubishi Televison & Video
I need the codes for a GE universal remote for a Daewoo TV
Welcome to FixYa!
You can try the following GE Universal Remote codes for Daewoo TV:
0130
0004
0009
0100
0005
0138
0043
0140
0039
0252
0279
0444
0080
0042
0058
0017
0010
0126
0018
0127
0019
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
If none of the codes listed work for your device try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER button (Should your remote model not have an ENTER button, then press the OK button.) The INDICATOR LIGHT will go off.
Thank you for using FixYa!
Have a great day.
Jas247
Apr 20, 2011 | Televison & Video
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
WMC PC and TV no longer communcating by remote
For the remote : try replacing bateries
Device driver : try reinstalling the tv tuner from the device manager.
Please name you model number of ur pc.
Jun 20, 2009 | Dell Dimension 3100 PC Desktop
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic CT-32HL43 32" TV Logo
123 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
