Watts Copier Our copier quit working. There is a light that looks like a sun that it lit up - I'm new here and have no idea what it means but, need to get it working. Any help would be greatly appreciated.
  • george eisener May 11, 2010
    what brand and model please
  • 183 Answers
You are new ok but you need to tell to us which is the brand and model of the machine for we to be able to help you
Posted on Jul 15, 2009
What is the meaning red light like a sun significant
hi your copy machine is indicating to replace developer or try reset it . if the copy is clean just reset it it will work for no. of copier. how to reset (c intrupp # intrupp ) then 42 sub code 01 hope it will help u.
thank You
Jul 18, 2011 | Sharp AR-5320 Black and White Copier
WE HAVE MODEL #EP1031F. THE "READY" BUTTON DOES NOT LIGHT UP, COPIER DOES NOT PRINT. THERE IS ALSO AN ICON LIT UP BY THE COUNTER WINDOW THAT LOOKS LIKE A CROWN. IS THIS INDICATING IT NEEDS...
Have you installed a new toner??? It may take a few minutes for the copier to add enough toner to make a copy. It's been awhile scince I've worked on one... But I think if you turn it off and hold down the Clear/Stop botton when you turn it back on, it will make the copier add toner... It looks like the display i chashing a box in the display. Good Luck
Nov 01, 2010 | Minolta EP1031/1031F CS/PRO Copier
Power consumption in watts of canon ir3220
Look on the back of the copier. If it doesn't show watts calculate yourself. amps times volts. For instance 120 volts at 15 amps is 1800 watts. Keep in mind this does not use that all the time only when all is on and running, and even then only when the fusing heater lamps are activated. Also look at the paper deck if it has one to see how much power it uses and just add its watts to your copier watts. Add the watts plus watts. The paper decks are minimal compared to the copier. So just going with the copier is enough. Always have a dedicated power source for the copier, because newer copiers are digital. They cannot be hooked to the same plug as a refrigerator or soda machine etc. Noise enter the power line and can cause the copier to do strange things. Always make sure the power plug ground when measured against neutral is less than 1 volt ac. Anymore than that is trouble with digital circuits.
Jun 07, 2010 | Canon imageRUNNER C3220 Color Copier
Little man icon lit up as well as the sun like button
like the sun light means that change developer
May 25, 2010 | Sharp AR-M205 Copier
Help with HP Photosmart C4340 All-in-One Series - new, barely used Copier quit working Printer prints only in light blue - barely readable
By new and barely used, do you also mean then, still under warranty? If so, return and exchange :-)
Sounds like an ink cartridge issue, though. Try swapping the cartridges out.
Jun 23, 2009 | HP Office Equipment & Supplies
Red light
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Sep 16, 2008 | Sharp AL 1631 Copier
Sharp AL1631
if it looks like an m or w it means there is a paper jam somewhere, most likely the fuser.
Open right side and look inside the copier, where it gets hot.
do you see a crumpled pice of paper there?
you may have to remove four screws to get the paper out
Jul 30, 2008 | Sharp AL 1631 Copier
Sharp AL-1641CS Lase Copier
http://www.retrevo.com/s/Sharp+AL-1641CS?rt=pd
Here is the location for your copier manual. You'll be able to view & download. Good Luck :0)
Jan 10, 2008 | Sharp AL-1641CS Laser Digital Copier
19 people viewed this question
jasbo
jasbo
