Question about HP Pavilion dv6000z Notebook
Ei systems 4411 wont power on
Ei systems 4411 when i press on/off button i get 3 green lights come on for about 3seconds then nothing the cpu fan does not spin could it be i need a new processor which is skt pga378 p4 2.4 thank you jake
    President:
  • 2,600 Answers
The most likely cause of your ills is a failed motherboard Jake. Processors are pretty tough but unfortunately HP did a lousy job with the motherboards on the DV series and many, many of them fail and usually after the warranty is over.
Posted on Jan 05, 2010
Ei System 4411
Here's one link for your solution:
http://www.crucial.com/upgrade/Ei+System-memory/Ei+System+-+All+Models/4411-upgrades.html
Mar 31, 2014 | Computers & Internet
Ei systems 4411 wont power on mains or battery
Try pulling out and putting back in place the ram modules, the motherboard can be faulty.
Oct 30, 2008 | Computers & Internet
Computer wont start up
your computer fails to both there is a problem on you hardwares.here are some steps to diagnose your cpu..
1.reset all your your PCI/PCIE cards.pull it out from the socket and plug it again.
2.did you hear a beep code after you press the power button?
a 1 long beep indicates a faulty on videocard replace it
no beep dead mother board.
3.remove the IDE connector for your hardisk and try to booth the system....
4.Try to reset the bios by removing the CMOS battery.
Jun 15, 2010 | Dell Dimension 2400 PC Desktop
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
T2893 e machines wont turn on
It sould be as simple as the on/off switch being bad .. the power supply could be bad .. it is powering the 'led' enough but it is faulty and cannot power the machine.
Try disconnecting all the components .. cd, hard drives, floppy ,etc .. but leave the power plugs on the motherboard .. try ...see if the CPU fan or power supply fan spin up..
Jan 04, 2009 | E-Machines T2893 PC Desktop
Ei systems 4411 wont power on/mains or battery power
If the fan does not spin, the unit is shutting down to protect the processor. I would have the fan replaced . Do not attempt to use the laptop, it may cause extensive damage if it overheats.
Joe
No Power with 3 red light
hmmm.. The Ring of Death.
The 4 rings mean power faliure.
The 3 rings mean the CPU has been melted.
The 2 rings mean there is a CPU overheat error.
The 1 ring means there is an internal error.
Hope this could of helped you.
Jun 05, 2008 | Microsoft Xbox 360 Console
Abit av8
Ensure that you got the cpu fan connected to the correct place, the board has 2 one for the cpu fan andt the other for a system controlled case fan.
If that dont work check to see you got the power supply connected to the board propperly, there is a seperate 4 pin connector using 2 yellow and 2 black wires ensure it is correct.
Check your power supply
unplug the power supply and bridge the green wire with the black one next to it to see if it comes on. OR JUST CHANGE THE POWER SUPPLY TO SEE IF IT WORKS.
YOUR PROBLEM IS A POWER PROBLEM EIGHTER FROM A BAD CONNECTION OR A WRONG HOOK UP AND IF NOT THAT A BAD POWER SUPPLY
Jan 03, 2008 | Abit AV8 VIA K8T800 Pro Socket 939 DDR 400...
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
HP Pavilion dv6000z Notebook Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
