Question about Goldstar MV-1526 Microwave Oven
Reset Microwave after a Power Outage
I have a Goldstar MV1526W Microwave Oven. We recently had a power outage and the oven displays ####### on the LED but the control panel is non-responsive. I've tried unplugging and waiting and plugging it back in. I've tried hitting varius buttons on the touch panel - nothing. I am renting and don't have any manual for this unit. Can anyone help???
  • 3 more comments
  • Cathleen O'Connor Sep 12, 2006
    Thank you Techman - much appreciated - Cathleen
  • Anonymous Nov 16, 2007
    My Goldstar just went dead. I checked the power source and that is fine. It was fine when i left for work came home and nothing.
  • Anonymous Mar 13, 2014
    We had an extended power outage today and when the power came back on the micro drawers lights didn't even come on. We have done everything in the manual from checking breakers resetting the GFI plug. This machine is hard wired in so there is no plug and unplug procedure we can do. No power or lights come on on the panel. Any more suggestion?
  • Anonymous Mar 24, 2014
    Tried unplugging, checked power level still won't heat
    President:
  • 3,130 Answers
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Posted on Sep 12, 2006
SOURCE:
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
Have a magic chef mco160uw microwave. Had a recent
No! there is no reset, the power surge has more than likely damaged the keypad controller, and on the back is a circuit board that has the microprocessor with additional components that controls the vital areas of the microwave oven. If that is gone, it is cheaper to replace than to repair.
Feb 06, 2011 | Microwave Ovens
Power outage for the microwave, fan still works although. any reset button?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 22, 2010 | GE JVM2070 Microwave Oven
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
Power on a MV1526w Microwave!!
Yes, the display should always be on when plugged in.
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 24, 2008 | Goldstar MV-1526 Microwave Oven
MR95TW
i need to buy the mr95tw micowave to replace the one i have becouse of the size where can i buy it at?
Jan 08, 2008 | Welbilt MR95TW Microwave Oven
Microwave no power
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. I tlooks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Dec 28, 2007 | Goldstar MV-1526 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
418 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Mike
Kevin
Kevin
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
