Kenwood DP-860 CD Playerwill not power up.
I have an old Kenwood DP-860 CD player. It will not power up. I removed the back and I found voltage through the switch and to the transformer. I do not see a fuse. On the other side of the transformer there is a multi wire connector. I see voltage but I have no schematic to follow. Maybe it is something easy. Thanks for the help...
DiMiS
  • 11 Answers
SOURCE: How do I replace a damaged power supply transformer on a DN-600F ?
Hello there. i'll suggest you one quick solution but it maybe dangerous!(Do it the greek way :P) try to remove the transformer from the machine. Take one Ohm meter and measure the resistance of the 120 vac coil. IF THERE IS NOT ANY (i mean that the ohm meter shows nothing diferent than not using it) get a paper blade and start removing the paper cover that it has rounded from the place where the 120 vac wires goes. you will see there that there is a mini thermal fuse.short circuit the thermal fuse and try to measure again the resistance of the 120 vac coil. if you see something between 40 and 80 ohms you are ok. Now that you haven't got any thermal fuse on your transformer just increase your security putting on a 300 mA fuse at the 120vac coil. I have done it with many hard to find transformers and it worked for me.Just be sure that when you plug it on, you will not touch it because i don't know if you are gonna do it right.ok? (say ok!) That was the second solution to your problem. The first and the safest is to go to your local dealer and order a new transformer.
Posted on Aug 10, 2007
latino
  • 93 Answers
SOURCE: need the wiring schematics
http://inform3.kenwoodusa.com/manuals/KDCX589.pdf
this link could help you
Posted on Oct 29, 2007
  • 112 Answers
SOURCE: power transformer problem
You need the service manual for those values. A quick google search shows it costs more than the replacement transformer! http://www.google.co.uk/search?hl=en&q=XG539A00+&meta=
But that is for the 110v version @$21. The same company sells the service manual @$24 or just keep googling.
Posted on Jan 25, 2008
mjap
  • 107 Answers
SOURCE: Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Posted on Jan 30, 2008
SOURCE: kenwood cd player DP-M6010
After retrieving the cds from the unit I replaced it with my iPod. It seemed to me to be the most cost effect method to solve the problem.
Posted on Feb 09, 2008
My kenwood CD player; model DP-R896 does not open cd tray.
hi Nicole.
there is a few ways to open this.
but if you go to this link and pick the best way you think will help you out.
kenwood CD player does not open cd tray Google Search
Nov 27, 2017 | Kenwood Audio Players & Recorders
Does not play has e22 on display on my kenwood dp-m6010 disk player
On the kenwood dp m6010 6+1 cd player, the e-22 and e-21 codes are for the laser head movement limit sensors. More than likely the drive belt is broke or stretched.
Jul 27, 2013 | Audio Players & Recorders
I have a DP-R6080 or DP-R5080 5 cd changer player. Its probably 10 years old or so but recently the CD have begun to skip. Its not the CD because the new ones skip and they play fine on a single player...
The trouble lies in the laser pickup assembly, the only option you can try is buy CD cleaning kit and follow the instructions, the kit will remove any dirt that might have collected on the laser lens, If it works you will get more usable time out of the machine. The fact that you got 10 years is much better than the average, overtime the laser gets weaker until it can not track properly, so! if the cleaning fails it is far cheaper to replace than to repair.
Mar 15, 2011 | Kenwood Audio Players & Recorders
Kenwood single cd player dp-2030. I insert cd, it reads fine responds but I get no sound.In the back of unit speakers are plugged into line output.
Speakers don't generally run off Line Out. What kind of speakers? You probably need an amp for the speakers. Unlike wiring is usually a clue to incompatibility.
Mar 03, 2011 | Kenwood Audio Players & Recorders
I have a kenwood dp-r99 cd player and the cd is stuck inside with an ee message. How do I open the CD player?
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
Nov 07, 2009 | Kenwood CD-206 5-Disc CD Changer
Kenwood stereowith A-58 Amplifier, no manuals, so can't set up
mine does the same and it cost 100 pounds to have the output chips replaced
Apr 08, 2009 | Kenwood Audio Players & Recorders
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
167 people viewed this question
 Grubhead
Grubhead
