Question about ASUS M2N32 WS Professional nForce 590 SLI Sempron/Athlon 64 SktAM2 DDR2 ATX Motherboard w/Au
Processor fan After statring up the fPC the fan is spinning up, but a little later de fan stops..(this is a new working fan)then the BIOS says the fan speed is to low.. what is the issue
  • agbontam Oct 31, 2008
    Sorry replaced it already with a brand new one..and as said it spins up and after disk messages it stops.without starting up again
  • 849 Answers
Fan gone bad, replace it,
Posted on Oct 31, 2008
Dell latitude e6400 fan not spinning
Is the laptop running hot? Sometimes the power saving mode in the BIOS will shut off the fan to conserve power when the processor isn't in danger of overheating. Try getting into the BIOS and playing with the fan and power saving settings to verify that the fan actually works as installed in your system. Otherwise, if you know that the fan works and you have it plugged into the system board correctly, there must be an electrical malfunction internally on the laptop and there is no way to troubleshoot further unless you know a lot about circuitry.
Jan 08, 2013 | Dell Computers & Internet
167 bios
To troubleshoot processor issues, follow these steps and test the processor after performing each one:
Notes:
  • If either the system board or processor have been replaced, reflash the BIOS to the latest level before proceeding.
  • Some computers allow the fan to stop spinning. This is not a malfunction. The fan should start spinning as the system heats up.
  1. Ensure the latest BIOS code is installed. This will correct any 167 POST errors for the Intel microcode update and "176 No Processor CPUID" post errors.
  2. Reseat the processor and the heat sink
    Note: Do not touch either the processor or system board contacting surfaces. These can be extremely fragile and bent pin damage due to touching is not covered under warranty.
  3. Verify the processor fan operation is not blocked by cables or other hardware.
  4. Verify that any replacement processor is the correct architecture for the system.
May 25, 2011 | IBM NetVista PC Desktop
Hi, for some reason, after Windows 7 has loaded the fan stops spinning on the Ageia PhysX card. The fan also makes a weird noise which it never used to do. Do u know what's wrong with it? It's...
In BIOS the fan always runs at full power, in Windows the speed is supposed to be automatically adjusted, depending on how heated the processor is. In your card it appears that the fan is dying, no longer capable of running at anything but the full speed. You will have to replace it - follow this
http://www.squidoo.com/video-card-fan-replacement
May 22, 2011 | BFG Technologies AGEIA PhysX 128MB GDDR3...
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the...
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Oct 09, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Processor fan failure massage.
I supose the fan works, you then need to enter bios and disable cpu fan monitoring, if the fan doesnt spin connect it to another fan connector or a plain 4pin molex connector / might require a adapter.
Try to get into bios and disable cpu fan fail alarm, keep the temperature alarm on 80 or 70. so it will yell if it gets too hot.
Apr 17, 2008 | Intel Motherboard
New motherboard and cpu: no post
I have encountered that kind of problem before in the AMD processor. When your turn on the switch the fan is spins and then suddenly stop. The processor is shorted or there is defective parts you need to return it to the supplier. But can you check first if the motherboard and the processor is match . Maybe the motherboard cannot carry the speed of the processor it's better to ask to the supplier or ask them to test both the processor and motherboard .
Apr 17, 2008 | MSI 945GCM5 Motherboard
Cpu fan stopps
try to clear cmos with the jumper next to the mainboard battery
hit delete enter setup bios and save changes
chek if the main board is not in unapropriate contact with the metal case.
chek the fans power connector pins in the board
and finally make sure that ur power supply is functionong properly.
Nov 14, 2007 | Computers & Internet
ASUS M2N32 WS Professional nForce 590 SLI Sempron/Athlon 64 SktAM2 DDR2 ATX Motherboard w/Au Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
