Question about Sanyo PLC XU50 Multimedia Projector
Sanyo XU50A will not recognize any input
The Sanyo X050A projector powers on correctly but will not recognize input from any of the sources. I have tried the RGB input, the usb video input, the s video input, and the rca input. I have checked settings in the menu but still no input detected. It was working fine and then Nothing!
Marrie
  • 563 Answers
SOURCE: 3M MP7740i Projector no input is detected
Hi mrus821
If the signal won't go through you will have to either have your Mainboard Repaired or Replaced.
This is unfortunatelly a common Mainbaord problem , and the above is the only way to get it fixed.
Posted on Apr 23, 2008
Marrie
  • 563 Answers
SOURCE: Panasonic PT-L501U
Hi BEEZELLE
Does the VGA input work ?
If not then the Mainboard is at fault and will need either repair or replacement.
Posted on May 13, 2008
SOURCE: Optoma EP716 source detection
I had the same and it turn out to be that my VGA cable was broken
Chyneeman
Posted on Jul 01, 2008
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
robgarcom
SOURCE: Sanyo PLC-XU58 projector completly dead
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure.
Posted on Oct 12, 2008
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
I have a Sanyo projector that shows a completely blue image - I can see the computer image but it is completely blue - Whet I press the menu button the normal colours come up for the menu
it sounds like the wire you are using to connect your PC to projector is bad
if color is normal when menu comes up then it is not projector unless the input for your PC is bad
i would try new cable first since that would be cheapest
do other sources in other inputs work???
Mar 28, 2011 | Sanyo Office Equipment & Supplies
I have connected laptop to infocus projector and both are powered on. I have pressed Fn/F4 to toggle the laptop to project. However, Nothing will project!!! What can I do. I have checked the connections...
make sure you have the settings correct on the projector. select computer on the top panel. if still nothing, reset the settings to factory default (in the menu). also make sure you have matched resolution.
Nov 21, 2009 | InFocus ScreenPlay 4805 Multimedia...
How to get tv working on the projector
It depends, check if your TV has Video Line Out (yellow pin) jack at rear then hook it in external video source/ input of multimedia projector to watch TV picture through projector.
Thanks.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
No Signal when plugging into laptop
On your laptop you have the ability to toggle the external display on/off/both. On several laptops I see, it is a combo of teh Function Key+F4 (or F5). The key for your laptop (you did not provide type) should be marked with an image of a projection screed or a monitor in a color matching function key; often blue.
With everything connected, press these keys to toggle from Laptop Display Only to Projector Only to Both.
If the problem is not your laptop, then verify the input source that the projector is looking for via it's menus or a button on the remote. Toggle the source if required.
Aug 05, 2009 | Sanyo PLC XU35 Multimedia Projector
PROJECTOR WON'T PROJECT IMAGE
check the lamp, if it is bad, there are many places to get the lamp, http://www.partstore.com/
is a good place to start
Feb 18, 2009 | Sanyo PLC-XU50A Multimedia Projector
Not recognizing any source
Hi, i hope this works for you, all you need to do is press the source button this makes the projector search for active inputs.
Nov 06, 2008 | Acer PH110 Multimedia Projector
Sanyo plc-su50 projector - can't get it to work
Please select correct input in menu of projector, that is Computer/ PC, like that...
Aug 02, 2008 | Sanyo PLC-SU50 Multimedia Projector
Sanyo PLC XU50 Multimedia Projector Logo
129 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
