Question about Philips 60PP9401 60" Rear Projection Television
Power ON: Only sound is chirping sound-No picture
Noise appears to come from inside, bottom left if facing tv. Tried turning off restarting. No go. Any technical help would be greatly appreciated.
    President:
  • 3,130 Answers
The chirping inside this set is an indication that theres a short in the set, and is loading down the switch mode power supply. This is not a job or the lay or handi person. Your going to need to know how to troubleshoot solid state electronics, and use a multi-meter. Your also going to need to use a schematic to trace where the short is. Please seek out a pro to assist you in this repair.
Posted on Sep 12, 2006
SOURCE:
Picture went out then a beeping noise started
it sounds like a dew switch it shuts down the power when it sences moister
Jul 06, 2012 | RCA Televison & Video
Tv screen black, makes a chirping noise
This tv problem are also part the tv Convergence board problems too.The tv convergence board are toally dead have no power voltages activity to the tv convergence board at all.That why u only have chirping sound only.If ur tv convergence board that have some power voltages activity left and have dying parts on the tv Convergence board only.Tv will have picture but have problems R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures only.The tv convergence board must be repair like replaced 2 STK convergence ICS and some or all it resitors too.Will fix the tv convergence board will fixed the DLP tvs with chirping noises too.The tvs shops will cost u like $300-$350 for parts and labors to fixed the tv convergence board.
Aug 23, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Chirping noise
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Jul 16, 2007 | Philips 60PP9352 60" Rear Projection...
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
Jan 29, 2007 | Philips 32PW6506 32" TV
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
