Question about Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 ADW
My JennAir quit working. The control panel still works. The time is displayed and you can select a cook time but the microwave never comes on when you hit the start button. The timer begins counting down the time and the light comes on, but nothing happens. Any advice would be much appreciated. Thanks
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: jennair
Do the inside light and cooling fan come on when you press Start?
If so, the problem is likely to be in the high voltage section.
If not, then the problem is likely to be related to the door switches or possibly the controller.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Your model may also have a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
Need to replace JMC7000 Microwave
Yours will likely have a bad high voltage diode, transformer or magnetron, all of which are covered under the extended parts warranty for five years from the date of purchase!
All you have to pay is labor, unless it's less than the two-year full warranty, then there's no charge.
That's a really great warranty!
It's on the back page of the owner's manual.
If you opt for replacement, Jenn-Air Customer Care can tell you which model would be a "drop-in" replacement.
Jan 06, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn Air Microwave won't cook
I had the same problem with mine wich is the same built in Jenn Air jmc7000 after using an ohm meter to check some of the switches I discovered the door swith was bad replace it for about 5 dollars and it works as good as new...Good Luck
Jan 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
Jennair microwave built in above oven. Clock and controls still work but no cooking. Timer even counts down. Any known solutions?
Mar 20, 2008 | Jenn-Air JMC7000 Microwave Oven
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
JennAir Microwave worked one minute then won't the next.
If this microwave is more than a couple of years old, it's possible that the magnetron tube or a rectifier has burned out. You'll probably need to take it to an experience microwave service technician to get a diagnosis.
Jan 16, 2008 | Microwave Ovens
How do I fix a Jenn-Air JMC7000 that does not heat up items?
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 06, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
52 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
