Question about Singer White Speedylock 1634
How do I dis engage the cutter
I want to use my serger without the cutter, Does anyone know how to disengage the cutter?
Thank you
    Problem Solver:
  • 15 Answers
What does your manual say?
If the 1634 is anything like the 1600 I don't think you can disengage it. I have the book for the 1600 and there is nothing mentioned about disengaging -- only changing the blades. Some models are like that. You might join the White serger group and ask the members there..
http://groups.yahoo.com/group/white_model_sergers
Someone may have an answer or a way around it.
Otherwise, all I can suggest is to call or go to a Joann's or a Husqvarna Viking sewing machine dealer and ask them. Alternatively, a sew and vac repair shop may be able to assist.
Posted on Oct 31, 2008
Is Janome L-344 sewing machine compatible with Side Cutter/Serger Attachment?
this is a low shank 5mm front load machine so yes there is a side cutter available. This will not replace having a serger by any stretch of the imagination
Jul 09, 2014 | Janome L-344 Mechanical Sewing Machine
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
My serger won't cut
Sounds like your blades are either dull, misaligned, disengaged or broken. Examine your serger book for how to re-engage the blades. If they are engaged, make sure they are aligned correctly. If that still doesn't help check for damage.
Sep 10, 2012 | Brother 925D Serger
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
How do you get the blades to cut on a hobbylock 794 serger
It should just cut. Don't know too much about this machine as I'm new owner, but from what I can gather, either you need a new blade, or the upper knife is disengaged. The metal knob inside the threading area should be turned downwards, engaging the upper knife. The upper knife doesn't usually need replacing unless damaged, apparently. Hope this helps somewhat.
Dec 04, 2008 | PfaFF Hobby 4260
My viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Nov 05, 2008 | Husqvarna Viking 1
Singer White Speedylock 1634 Logo
474 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
