Question about Compaq Computers & Internet
67152m notebook is completely dead. Have replaced the AC adapter but still nothing
    Problem Solver:
  • 4 Answers
Sounds like the internal power supply has packed up. If the laptop AC suply does not show a light or warm up after say 15 mins then it could still be a faulty adapter. If however it does warm up or the light shows on, then it is almost certainly the internal power supply and unless under warranty is a £150+ job unless you want to try yourself. One final thought. Have you tried removing the battery and putting the AC adapter on just in case there is a short on the battery?
Posted on Oct 30, 2008
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
No power
Reset the memory modules and any other cards that are accessable, like the WIFI and modem cards.
Power up your laptop, does it work normally?
If not, then try rhe following steps.
Does it work when the battery is removed and the AC adapter plugged in?
If so you may have a bad battery.
Try this, unplug the AC adapter and remove the battery for a few minutes, leave the battery out and connect the AC adapter, power on your system, does the laptop work normally?
Power down, and reinstall the battery, with the AC adapter still connected, power up your laptop, does it work normally?
If not, the battery may be defective.
If NONE of the steps work then *********** board needs to be replaced.
I hope this helped, good luck and have a nice day.
May 26, 2010 | Computers & Internet
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Sir,
  1. Press and hold the power button down for 10 seconds.
  2. Make sure that the power and hard disk light-emitting diodes (LEDs) are on.
  3. Check the power cable connections:
    • From the electrical outlet to the AC adapter.
    • If applicable, make sure the LED on the AC Adapter lights.
    • From the AC adapter to the notebook.
    • Make sure that the power strip is on.
    • Make sure that the surge protector is on.
  4. Try another electrical outlet.
  5. Disconnect any external devices, like PC cards, digital cameras, or external drives.
  6. Disconnect the notebook from the docking station (if applicable). Remove any power strips and surge protectors. Plug the power cord directly from the notebook into the electrical outlet.
  7. Remove the battery and reinstall the battery. Refer to the documentation that came with the notebook.
  8. Remove any newly installed software or hardware.
  9. Remove any additional memory. Refer to the documentation that came with the notebook for memory removal instructions.
  10. Shut down the computer, and then remove the drives. Refer to the documentation that came with the notebook.
  11. Push the hardware reset (if applicable). Refer to the documentation that came with the notebook.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 21, 2009 | Gateway GT4024 PC Desktop
Compaq nx6320 won't power up
Replace your battery Some laptops don't boot up when no battery is present even it is connected directly on the power supply. Or if not to visit your nearest HP service center. If its still with warranty, use it.
Good luck kabayan. ^_~
regards,
-engrkoiled-
Mar 27, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
The AC adapter that I brought from Best Buy doesn't have enough power to get my computer to- charger-up. The S/N of my computer is T3A6931000974. The tec from best buy said that the adapter didnt have...
Looks like a 90 watt AC adapter will do what you need
http://www.batteryfuel.com/ac-5001sp-gateway-mx6955-laptops-90w-universal-notebook-ac-adapter.html
Sep 05, 2008 | Gateway Computers & Internet
Hi when i turn my ACER 5315 LAPTOP on it runs for 5-10secs before turning off again please help thanks
We can try some work around to narrow down the issue.
I think your notebook might be getting power from the Ac adapter. The remaining power in the battery might be giving power for few seconds and trning OFF again.
To check this, once remove the battery from the notebook and turn on the laptop with only AC adapter.
If there is no power at all, then what I guess is correct. Issue might be with the AC adapter or with the power jack on the motherboard.
If the notebook turns ON even with the Ac adapter and turned off aftetr few seconds without battery, then you have to contact service center as it could be the hardware issue.
Aug 09, 2008 | Acer Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
