Question about Frigidaire FRS26KR4A Side by Side Refrigerator
Evaporator Coils only Frosting on top half
I guess our problem is actually the evaporator coils are only frosting partially. Only about the top half. We had a repair man come and look but he didn't seem to really know what he was talking about. Is it possible to correct this problem ourselves? Thanks,
    President:
  • 878 Answers
Skap, sounds like a restriction or a leak in the system somewhere, covered under warranty for 5 years parts and labor. Need a cfc certified tech to repair...Catriver..post back
Posted on Sep 11, 2006
FREEZER COOLING OK BUT FRIDGE LOW COOLING
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor.
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | White-Westinghouse WRSZ28V8GM Side-by-Side...
I have a daewoofrg1820brb I've had it plugged in 4 2 hrs now freezer is cold but the bottom isn't getting cold
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor. Cause 3
Apr 09, 2016 | Refrigerators
I have a msd2641kew Maytag side x side
yes it is possible , it could have caused a restriction. if evaporator coil has a slight frost pattern from top to btm then your compressor and Freon are good and no restriction . if your evaporator coil is only frosting up only a little then you have a freon restriction.
if you just cleaned the coils today , it takes up to 24 hrs to get back to 100 % .
Oct 10, 2014 | Refrigerators
My up right freezer in frosing at top inside part of the unit.
Frosting on evaporator coil should be evenly distributed all over the coil. If the frosting only appears up on the top around where the refrigeration line enters then the gas pressure is too low - if you add refrigerant the frosting will move down to cover the bottom coils also.
Nov 26, 2013 | Kenmore 20.3 cu. ft. / 575 liter Upright...
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
Freezer stopped freezing. The Freezer had alot of thing in it, once i took the stuff out he fan came on... Also, cant tell how the controls work... they are dials that say colder / Warmer with numbers....
The freezer not freezing can be 1 of 2 problems, the first being a defrost issue. If the defrost timer or defrost thermostat are bad they will not activate the defrost heater in order to keep ice from building up on the evaporator coils. In order to find out if this is your problem, remove the panel off of the inside of the freezer to expose the evaporator coils. If there is a lot of ice build up, this is your problem. The second problem will be that the compressor is low or out of freon. You will know if this is your problem if the evaporator coils are only partially frosting, there will be NO ice on the coils if this is your issue. This problem can only be repaired by a certified technician. If it ends up being just a defrost problem you can order the parts to repair it at Reliable Parts, using your model number to look up the parts. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 22, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Food defrosted in top of upright freezer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost thermostat, heaters, or trimmer
Hope this helpout and Good luck
Jul 28, 2010 | LG LRTP1231W Top Freezer Refrigerator
Frosting up around condensor etc , and the warning light on.
Are you frosting up at the condensor or did you mean the evaporator? If its the condensor then make sure the coils are clean. Still then you will need a tech to look at the seale system. If its the evaporator and the heater is ok then it could be the timer or the terminator on the compressor. Most of the time its the timer.
Sep 14, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Frigidaire FRS26KR4A Side by Side Refrigerator Logo
498 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
