Question about Lexmark Wheelwriter 15 Series II Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Problems
Prints okay on left side of paper, but after the first few inches, the bottom of letters don't print (both lower and upper case).
Is this an adjustment a novice/DIYelfer can handle, or do we need to call for help?
Thanks.
  • SqdLdr Nov 06, 2008
    Perfect solution! Many thanks.
  • Anonymous Dec 22, 2008
    the minus key on my wheel writer does not print
    Scholar:
  • 183 Answers
The right side of the platen has prabably come unlatched. Just push down on the right side of the platen, (black roller the opaper goes around) it should clunk down into place.
Posted on Nov 01, 2008
How do you clean the platen in an IBM Wheelwriter 15 Series II?
Remove the platen by squeezing the plastic lathes at both ends.
Clean it with mineral spirits and fine sand paper.
DickyO
Jan 16, 2013 | Lexmark Wheelwriter 15 Series II...
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
IWhen i turned it on it only types half the letters/numbers etc
If it is only typing the top half of the letters the platen may not be fully seated in the side frames, push down firmly on both ends of the platen it should snap into place.
DickyO
May 11, 2010 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
Keystroke on prints top half of letter
Most likely the platen is not fully seated press firmly on buth ends of the platen (black rubber roll) it should snap into place.
DickyO
Jan 29, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 10 Series II Typewriter
There is a plastic cap on the end of the print solenoid plunger whichis probably broken. They are available fron us for 15.00 including postage but can be a little tricky to install
DickyO
Dec 09, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
