Question about HP 640 Inkjet Fax Machine
HP 640 fax
About 2 days ago my fax stopped working. I checked the power. Reattached all the cables. Tried another device (it worked fine.) Unplugged everything and waited 10 minutes and re-plugged but nothing has worked. The display is accurate but there is no dial tone and makes no noise when dialing. Is it dead or is there another way to reset it?
The machine is less than 9 months old with very light use.
Michael
    Genius:
  • 2,120 Answers
Are you plugged into the LINE port?
Posted on Oct 30, 2008
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
HP 640 fax only displays bars nothing else will work
while the printer is powered on.....unplug the power module and then press and hold the # 3 button at the same time......while holding the two buttons reconnect the power module......will fix the problem.
Jun 01, 2010 | HP 640 Inkjet Fax Machine
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
HP 640 fax won't send fax but phone works
Unfortunately wer purchased two new hp office jet 7610 which do not come with cabling and we could not get the fax to work. I spent 3 days on the telephone with hp and British Telecom each of which blamed it on each other. After doing some research on the internet I discovered that hp require a strange cable formant which is called a 'cross-over cable' is required. I bought them from cabling4less.co.uk and the product code is BT-203X. They can be found on their web site www.cabling4less.co.uk The link is: http://www.cabling4less.co.uk/category.php?cat_id=237 This should resolve this frustrating problem.
Jul 23, 2009 | HP 640 Inkjet Fax Machine
HP 3310 printer will not scan a fax or slides
no problems man
:just take out the catriges..plug outthe power cable ....then plug it bacvk in after 20 secnds,the printer will ask fr printer catriges ,puthem back in and try to perfom fnctions ,still problem persists ,follow following steps
:just go ahead and take ou the power cable
and press and hold # and 3 fr 30 seconds
while pressing them plug in the power cable
:similarly perform with # and 6
:ur problem will be resolved
Jun 28, 2009 | HP Photosmart 3310 All-In-One InkJet...
Fax Machine not recieving faxes
Check your fax settings again follow the instructions on Printer menu and set the FAX rings to 5 or 10 and also check the paper settings and papers in tray. If not worked tell me the model of your fax machine.
Mar 14, 2009 | Brother MFC-7820N All-In-One Laser Printer
Won't send faxes to 817 area code, all others OK
The recipient may have a DSL phone line, or receiving to a fax server that blocks your area code.
Oct 14, 2008 | HP 640 Inkjet Fax Machine
Mp830
I had this problem and I UNPLUGGED the printer and left it over night. It reset and works fine!
Aug 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How can I install my fax HP640
All fax machines are ANALOG devices. They are designed to work on POTS (Plain Old Telephone System). Any other condition is a **** shoot.
Jul 21, 2008 | HP 640 Inkjet Fax Machine
Open Questions:
See all HP 640 Inkjet Fax Machine Questions
HP 640 Inkjet Fax Machine Logo
120 people viewed this question
Ben Johnson
