Question about Canon SPEEDLITE 580EX TTL Flash
Getting out of the Custom Functions menu
I am in C.Fn menu, did my adjustments but can not go out of the menu. The sign C.Fn remains on the screen and can not change the Mode to TTL anymore. I am supposed to press "Mode", but this does not help.
  • Trevpayne47 Dec 06, 2008
    I cannot set my gun to ETTL. It stays at TTL and the CFn stays on screen. I was part way through shooting a job when I noticed my photos were grossly underexposed. After checking the gun, I found it to be set on TTL. I cannot seem to get it back on track. Is it a fault that needs a repair?
Had the same problem, in the custom function menu choose C.Fn-05 and 0. This should rreturn your flash metering mode to E-TTL. Worked for me give it a try.
leebutt101
Posted on Dec 07, 2008
When I push '-' to make image smaller screen goes black
Check your setting in "Custom Functions". Sounds like your "-" (or more specifically your "*" button) has had a feature enabled. I had my "*" button set for focusing - under Focus Settings in Customs Functions. If in doubt reset all Custom Functions to their default.
Mar 05, 2014 | Canon EOS 40D Digital Camera
How to brighten my laptop screen
There are two 'Brightness signs' on two keys of your laptop keyboard.
Press 'Fn' key (on the last row of the keyboard) and press one of these keys to increase or decrease brightness.
Sep 10, 2011 | Computers & Internet
When I turn on my camera the shooting setting display menu comes up, but after I take a picture the screen just goes black. I can still take pictures and everything. I have a Canon EOS 1000D by the way...a
Okay, there are a few possibilities and things to check out if you haven't already found a solution to this problem.
First, it sounds like you've turned off the display by hitting the button. Page 42 of the manual describes hitting the , which toggles the display between being off and on. So, try hitting that button and see if that fixes your problem.
One other thing to check out is the LCD Monitor Off/On setting, which is described on page 115 of the manual. If you're still having problems with your display after toggling the button then check this setting and make sure that it is on the [Shutter btn.] option.
Finally, it's possible that one of the custom functions is affecting the behavior of the display. To get to the custom functions just hit then use the arrow buttons to select [Custom Functions (C. Fn)] under the second to last menu item along the top, as shown in the next picture from page 152 of the manual.
From there choose C.Fn-11 for "LCD display when power ON" and make sure it is set to 0: Display, which will turn the display on when the camera is turned on, instead of 1: Retain power OFF status, which will keep the display off when the camera is turned on.
Since it's been a while I imagine you may have already solved this issue, but if not, then I hope these troubleshooting tips will solve your problem.
Good luck and have fun. :)
Mar 09, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
How to set time on a logitech keyboard
  • Place the CD that came with the Logitech keyboard into your computer's CD drive. Allow the computer several seconds to load the contents of the disc.
  • Step 2 Follow the pop-up on-screen instructions to install the keyboard's set drivers.
  • Step 3 Plug the keyboard into the computer.
  • Step 4 Navigate to "Control Panel" in the "Start" menu of Windows. Then double-click on the "Keyboard" icon.
  • Step 5 Click on the "Buttons" tab in the keyboard window. This will take you to a screen where you can set the functions of custom buttons on the keyboard.
  • Step 6 Click on each button setting and use the on-screen options to set functions for each of them. Also, if desired, set custom functions for the "F1" through "F12" keys and others.
  • Jul 12, 2010 | Logitech Cordless Desktop MX3200 Laser...
    I need to lighten my screen
    this is not a computer problem you have to press the buttons on your monitor that is a menu when the menu comes up change the brightness
    Nov 14, 2009 | Averatec 7171000100 Keyboard
    My graphing calculator only allows me to graph one line at a time
    Once you enter an equation the corresponding equal sign is highlighted by default. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted. If one is not highlighted, move the cursor on it and press ENTER.
    Once all the = signs for all the functions ypu want to draw are highlighted permanently, press the [GRAPH] key.
    Depending on the functions ane the window dimensions certain graphs may not show up and one can Zoom out or adjust the window.
    If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER]
    Command PlotsOff echoes on main screen. Press [ENTER], screen displays Done.
    If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
    You shouild make it a habit to clear the RAM every time you start a new type of problem.
    Hope it helps.
    Oct 19, 2009 | Texas Instruments TI-84 Plus Calculator
    How do I recent my Canon Digital Camera?
    To reset factory defaults. Turn the dial to P (program). Turn on the camera. Hit the menu key. You will now see the extended menus. (if you don't turn to P you only get basic menu). Go to the last tab which is the second tools menu. Look down the menu and you'll see a "clear settings." Select this and you have two choices "clear all camera settings" and "clear all custom functions." Select "clear all camera settings." The "clear all custom functions" only applies if you've created custom functions which few people do. I hope this helps.
    Jun 18, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    Auto focus does not work in creative modes
    That is a custom function of the camera that can be change back to default with ease. While in one of the creative zones press the menu button and navigate to the 5th and final tab on the top right. 8f5da8f.jpg
    This is the Setup menu 2. In this menu, select “Custom Functions (C. Fn)” . This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. 7528356.jpg
    That should get your camera back to the expected auto focus with the shutter button.
    Mar 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    Auto focus does not work in the creative zone
    Sounds like your custom functions have been changed to work this way. On the EOS 350 D it is Custom Function #04. To change it back to default you need navigate through Canon's menus. Here's how to get there: while in one of the creative zones go to your camera menu and navigate to the 5th tab on the right. Select “Custom Functions (C. Fn)” from this tab. This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. That should get your camera back to the expected auto focus with the shutter button.
    Happy shooting :-)
    Feb 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    Canon SPEEDLITE 580EX TTL Flash Logo
    232 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
