Question about Boss DVD5000B Car DVD Player
Wont eject DVD
It wont eject the DVD, it had been working fine, now it wont eject and keeps coming up with 'er1' whatever that means. How can I get the disc out?
0 characters
1 Points
Dvd wont play and wont come out, it just says eject disk
there should be a reset botton on the radio if this does not work you will have to send it to kenwood to get fixed
Aug 09, 2009 | Kenwood DDX-6019 Car DVD Player
DVD player wont eject
Try Turning the unit off and then back on. As soon as you turn it back on push eject .
Jul 25, 2009 | Audiovox VOD102 Car DVD Player
Cd won't eject
After you hit the button...and it beeps....tap on the screen...where the color display is....not too soft but not so hard that you crack it....then it should open after a few times of tapping it and hitting the button. I found this at another forum, and it worked for me.
Jun 10, 2008 | Pioneer AVH-P6600DVD Car DVD Player
Quit working
check your car's fuse, if it is burned it means you might need a more powerful one. Mine has a 15 amp and works fine.
Mar 20, 2008 | Jensen's VM9312 Car DVD Player
Lanzar model SD43MU(( dvd/cd player wont work not funtions for that wont even appear?
I have a similar Lanzar unit. I had it in twice while it was under warentee for the same issue. I also had it in a couple more times for other issues. It cost me about $30 shipping both ways each time I returened it. About a month after the warentee expired, the DVD quit ejecting again.
Bottom line, I would look at purchasing a different uint or use an ipod instead of the CD.
Mar 01, 2008 | Lanzar SVD26MUT Car DVD Player
Doesn't eject my disks
I held my eject button down for more than 3 sec and it spit the DVD out and cleared the eject code when I reinserted it. Try it and see. But make sure it's a CD/DVD you really don't care about.
Feb 02, 2008 | Kenwood DDX-6019 Car DVD Player
Jvc-avx1 wont eject
Try to power down the unit and the power it back up then press the eject button. If this does not work there might be a hole in the front of the unit which you could insert a paper clip which will actuate a mechanical release switch.The last thing you can try is to open up the unit and manually rotate the load and unload motor and this will eject the DVD. Restore the cover and then start up the unit to see if things are ok.
Sep 16, 2007 | JVC KD-AVX1 Car DVD Player
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
Boss DVD5000B Car DVD Player Logo
43 people viewed this question
Top Boss Car Video Players Experts
Jose Velazquez
Jose Velazquez
Are you a Boss Car Video Player Expert? Answer questions, earn points and help others
