Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No water from door dispenser
I have a GE profile SxS aprox 2 to 3 years old and it will not dispense water at the door , makes ice OK , filter good, has power to the water valve.
When the micro switch is activated at the dispenser I get water flow at the disconnected coupling at the bottom front of refrig but nothing from there to the dispenser
sorry I forgot to get Model I believe it is 22 cf
  • rbarre20 Nov 03, 2008
    left it plugged in let it alone for the week end , came back and now works normal
  • bwjones Dec 12, 2008
    I have a seven year old GE PSI23MGMABB sis by side that I have intermittent water dispenser problems. After it stopped working, I followed GE's advise and held the dispenser arm down for two minutes to remove all air in the lines. This worked, but the problem keep coming back. If air is getting in the system, how and where is it coming from. How do I correct it.
    Bill J
  • 120 Answers
You have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Posted on Oct 31, 2008
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water won't flow to the ice maker but does to the door dispenser
make sure that the solenoid valve that lets water into the ice maker is working. you can also double check that there is no blockage in the supply line and at the solenoid.
Aug 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The ice maker is making ice but won't dispense any ice or water
Stop, the first thing to know is if you are getting voltage to the rotator srm in the back of the freezer
Mar 14, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
245 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
