Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
Benq Model 7200 PB7210 Lamp Issue
Lamp was going black when in operation. We ordered a new lamp and replaced it. When we turn the projector on the green light comes on however, the neither the lamp nor the fan come on.
  • 1 more comment
  • Larry1945 Oct 30, 2008
    When turned on the projector switch on back of unit, the power light on top is yellow and the temp & lamp lights are red and the fan does not come on. That is why I think the problem is beyond the lamp. Nothing happens when pushing the power button on top which has a green light.
    Per your instruction, I reinstalled the lamp and now the power, temp and lamp lights stay dark, but the power button and control lights are green. When I hold down the power button however, nothing happens. I turned of the unit, reinstalled the old lamp and got the same result. Could it be a switch issue?
    How do I perform that check. I am uncertain how you check to see if the lamp is open?
  • 2,071 Answers
Just replaced the lamp..
Posted on Jun 10, 2009
  • 905 Answers
This is a more serious matter in which you should not be messing around with it anymore
as this now should be looked at by a tech to determine the exact cause of it not starting up
it is most likely a electronic component causing the relay , fan and start up not to occur
please call an electronic repair shop near you to resolve the problem , and if you still have a warranty then use that
electech
Posted on Oct 30, 2008
  • jason Oct 30, 2008
    thank you , and I just didn't want you to void your warranty , because they will do that to people just to make more money from them ,
    a friend of mine went into his tv and he got a void on his warranty , they wanted $140 for a tv he paid $200 for, so that souldn't happen to anyone! again thank you!
    electech
    Genius:
  • 1,011 Answers
Dear,
check your lamp. is it open inside or became open due to some reason.. its new but you have to check its continuty and then plug it again properly if fine
regards,
    President:
  • 2,712 Answers
Check all connections, remove and replace the lamp. Unplug from power source for about 10 minutes, replug and try. If still having issues, call BenQ Tech support at 866-600-2367
  • Swilin Sampson
    Swilin Sampson Oct 30, 2008
    Some times, it may take a while to heat up before the projector can start. Maybe that is the issue? Anyway, I would recommend giving the BenQ tech support a call.
  • Swilin Sampson
    From the user manual:
    First, make sure all screws are tight. Loose screws can cause a bad connection leading to a malfunction.Do not power on when the lamp cover is removed. After replacing the lamp, you need to reset the lamp hours.:
    1. Press and hold the Exit button on the projector for 3 seconds to display the total used lamp time.
    2. Press the MENU button on the projector during the lamp hour message. An adjustment message will
    appear.
    • Press < or > to reset lamp hours.
    If the temp light is red and the fan is not running, the instructions require that you palce a service call..call BenQ Tech support at 866-600-2367
    Genius:
  • 2,035 Answers
Reinstall the lamp again and Check for the proper input source. Ensure all cables are connected properly ....
Good luck...
  • BenQ Master
  • 19,396 Answers
Remove the lamp and put it back in place, check the fan and the lamp connectors.
    Genius:
  • 1,550 Answers
You need to have a check over the lamp . There is chance that lamp might be defective one . Replace it .
Also check all connections .
Can I replace Benq MP515 projector lamp with Infocus IN102 Projector lamp ?
Hi. Just done some research and found the psu model for both projectors is compatible.
http://yylamps.en.alibaba.com/product/537179187-219545377/Projector_Power_Supply_for_Infocus_IN102_BENQ_MP515.html
Will continue looking.
Sep 03, 2014 | BenQ Replacement Lamp for MP515/ ST MP525/...
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
The projector will turn on normally, but after about 20 seconds the screen will go black and the "temp" and "lamp" alarm lights will flash on and off. I've changed the filter and we...
if you are replacing the lamp by yourself, and if you are touching the lamp body with your fingers, the lamp will be damadged fastly; because the lamp is sensible. the temperature of the lamp increase abnormally so the message 'temp' and 'lamp' increase. to solve the problem you need to replace a new lamp, but you have to install it at the BenQ service it's free.
Jan 02, 2011 | BenQ W10000 Projector
Hi. I have a Benq PB7210 and the color wheel is broken in it. I am having extreme trouble finding it. Can anyone tell me where I can buy it or if there is another model of which I can switch the color...
I would contact BenQ's web site and find the dealer list. From there you should be able to source a spare part but they may not be available as they don't break in normal service and are not a stock item requirement.
Hope this helps.
Nov 14, 2010 | BenQ PB7210 Multimedia Projector
Lamp burn out 3 time in 16months
clean out your projector. if there is a lot of dust and/or no air flow, the lamp will overheat and die. it needs to cool. use canned air and blow out any and all dust from inside the projector. make sure the fans work. also, don't buy lamps from "bob's lamps". get it from a reputable benq dealer.
Nov 10, 2009 | BenQ W500 Projector
Epson emp 61 projector
Could be a faulty lamp or placement issue. Are the fans operating in varying speeds? Have you had the lamp verified as working by the supplier or someone else who has this model.
Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Sep 10, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BENQ FLAHING
Hi cvijr
This can only one of two things - the lamp or the Ballast ( lamp's powersupply )
Normally the PB6100/6200 lamp's has got markings on the lamp itself when this flickering occurs.
Take out the lamp by unscrewing the lamp door at the bottom. Then look for any vein like looking marks in either black or white. Or even a bubble at the bottom end of the lamp's shaft.
If you can spot anything out of order , then the lamp will need replacement.
If not , then you'll know for sure that it is the Ballast that is in need of either repair or replacement.
Part Numbers :
Ballast :5D.J8612.011
Lamp : 60.J8618.CG1
Hope this is of help and thanks for using Fixya !
May 05, 2008 | BenQ PB6100 Multimedia Projector
Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Apr 07, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
183 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
