Cars & Trucks Logo
Anonymous Posted on Oct 30, 2008
92 Jeep Cherokee Laredo odometer broke
Guys,
My instrument cluster works fine Batt, Fuel, RPM, Coolant, Oil, and Fuel all work. Problem is my odometer(SPeedD) gauge is not working. Any suggestions on troubleshooting or repair. Already removed and reinstalled the cluster to insure connections.
Help
Mike
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 21, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1796
Points
12
I have the same problem on my 1992 cherokee...it's the vehicle speed sensor...it's located at the transmission/transfer case.....
1helpful
RPM GAUGE STUCK AT HIGH. Is this a transmission problem
What make , model an year vehicle ? Probably not a trans problem . Transmission has nothing to do with RPM gauge .More likely instrument cluster problem . GM vehicle's had a problem with stepper motors in the instrument cluster , these stepper motors are what control the gauge movement . This problem was 2003 to 2006 . Your best bet , take it to a qualified repair shop.
The odometer is not working on my 1999 navigator. It just says 0. What could be the problem?
Odometer The instrument cluster receives odometer rolling count status from the PCM-engine computer and stores the mileage in non-volatile memory (NVM). When the instrument cluster fails to receive the odometer rolling count status for more than two seconds, the odometer display will show dashes.
HEC Dealer Test Mode
To enter the HEC Dealer Test Mode, depress and hold the instrument cluster SELECT/RESET button and then turn the ignition switch to the RUN position. Continue pressing the SELECT/RESET button (5 seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within 3 seconds of the odometer displaying tESt to begin the dealer test mode. Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any continuous DTCs stored before proceeding to the next step.
All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster .
Odometer Display Description GAGE Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . bulb Illuminates all micro-controlled lamps and LEDs (low oil pressure/high coolant temperature, low fuel, service engine soon, brake, low range). INSTALL a new bulb or LED as necessary. r Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). If alternating flashes of FAIL and ROM level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . EE Displays hexadecimal value for EE level (used when requesting assistance from the hotline). If alternating flashes of FAIL and EE level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . dt Displays hexadecimal coding of final manufacturing test date (used when requesting assistance from the hotline). dtc Displays continuous DTCs. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step. enG Displays the English speed in mph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. m Displays the English speed data (mph) received from the PCM via SCP Network. Displays the metric speed in kph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. tAc Displays the tachometer data received from the PCM via the SCP Network. Tachometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if engine rpm is 0. FUEL Displays the actual A/D fuel level. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically. If the value displayed is between 0 and 20, the circuit is shorted. GO to Pinpoint Test D .
  • 255=open send +/-0
  • 232=Full stop +/-10
  • 215=Full mark +/-10
  • 178=3/4 mark +/-8
  • 138=1/2 mark +/-7
  • 93=1/4 mark +/-5
  • 41=E mark +/-4
  • 54="LOW FUEL" (0-59)
  • 0-18=short (0-20 max.)
OIL Displays the code (0-255) for the oil pressure switch input to the HEC. Displays the oil pressure reading input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6 psi) will display a value between 000 and 176. A low oil pressure (less than 6 psi) or an inoperative engine oil pressure switch will display a value greater than 176. dEGC Display of engine temperature in Degrees C input from cylinder head temperature sensor. If the value displayed is -40C, the SCP message for engine temperature has not been received for more than 5 seconds. GO to Pinpoint Test E .
  • 49 C="C" mark.
  • 60 C=Normal band start.
  • 120 C=Normal band end.
  • 119 C=Temperature warning indicator ON.
  • "-40" C=No SCP Message for 5 sec.
br Displays the brake fluid level input to the HEC. bAtt Displays the code (0-255) battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage.
  • 93-102=6.9-9.1 volts (Low voltage)
  • 115-124=8.5-10.7 volts (Norm band start)
  • 215-225=15.8-18 volts (Norm band end)
  • 230-241=16.9-19.1 volts (High voltage)
rhEo Displays the present hexadecimal value for the instrument cluster backlighting pulse width modulated (PWM) input to the HEC (used when requesting assistance from the hotline). rhi
rhS
rho PWM input duty cycle.
SCP hexadecimal dimming step (used when requesting assistance from the hotline).
Output driver counts in hexadecimal format (used when requesting assistance from the hotline). Cr Displays the present RUN/START sense input. Display will show -h with the ignition switch in the START position and -L with the ignition switch in the RUN position. ALtF Displays 8-bit hexadecimal value for alternate fuel level. Display will show a value between 00 and FF if the message is received. PA-PE7 Not used. GAGE Repeats test display cycle.
Turn the ignition switch to the OFF position or press and hold the SELECT/RESET button for 3 or more seconds and release to exit HEC Dealer Test Mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
1helpful
Instrument cluster for a jeep grand Cherokee 2004
ok i answered this yesterday.
search?
again, you can not marry a cluster, ever, with out factory scan tools. why would you try to use a USA miles cluster.
why? why not ask JEEP THAT, ;you will be told NO.
on many newer cars the VIN has to match too.
and the ODOMETER must be MARRIED, not by you.
the cluster has a self test mode (why not do that first????)
after checking both cluster fuse first., with a volt meter. (12v both side fuse is good fuse,keyon)
we do the self test next.
ask or read your other post its there.
1helpful
Where is the input and output connection for the instrument cluster on my 2002 Jeep Grand Cherokee Laredo?
A common fault disconnect the neg battery lead give it 20 min re connect should cure your problem.
Other tips about this can be found on Cnet:
I have a 2004 Jeep Cherokee Laredo. An indicator (with a symbol of what looks like a radiator) below the low fuel indicator (bottom left had side of the dashboard) lights up and remains on. I have checked...
2005 Instrument cluster layout
1. Speedometer
2. Brake warning light
3. Turn signal indicator light
4. High beam indicator light
5. Malfunction Indicator Light (MIL)
6. Airbag warning light
7. Anti-Lock brake warning light
8. Tachometer
9. Security alarm indicator light
10. Oil pressure warning light
11. Electronic Stability Program (ESP)/
Traction Control System (TCS) indicator light
12. Tire Pressure Monitor warning light (base)
13. Temperature gauge
14. Electronic Vehicle Information Display
15. Tow/Haul indicator light
16. 4WD Low mode indicator light
17. Seat belt reminder light
18. Cruise control indicator light
19. Odometer/Trip Odometer
20. Transmission gear indicator
21. Fuel gauge
22. Electronic Throttle warning light (5.7 Hemi)
23. Front fog light indicator light
24. Voltage warning light
11helpful
3answers
Speedometer, gas gauge, odometer, rpm gauge not working
My gas guage, speed odometer and tempiture does not work
The speed odometre is reading 9999999 what should i do
Instrument cluster on 97 Wrangler
IF YOU REMOVE INSTRUMENT CLUSTER AND UNPLUG IT,PLUG IT BACK IN AND UNPLUG IT AGAIN..DO THIS A FEW TIMES..IT SHOULD CLEAN OFF SLIGHT OXIDATION ON CONNECTOR TERMINALS..HAVE SEEN THIS BEFORE..I ALSO THINK REPAIR CONNECTORS AVAILABLE FROM DEALER
Check engine, gauge and fuel light on
I'd guess that the cluster died. Cheapest fix is a used one from a salvage yard. You want a yard that'll also install it, that way you'll know it works when they put it in.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
