Question about Kenmore Elite 45986 Front Load Washer
Not working with wierd symptoms
Okay..my bad. i overloaded my five year old machine with a down comforter. i won't do that again.
But since then, the machine sometimes works, sometimes doesn't. sometimes, when i try to start it, all of the lights blink all at once. if i give it a minute, then it calms down, stops blinking, and i can run the load. sometimes once the load starts, it stops a few minutes in, and then locks the door. if i reset it(i hit run, then cancel and the door unlocks), it will then run fine. or, the third symptom, when it does run successfully, the clothes just aren't dry enough...still very wet. so i have to run an extra spin.
any ideas?? help!
  • 566 Answers
Hi 5 years old ? from the symptoms you have described this is most probably the machines motor brushes are too low/worne as they all do in time this is not too difficult to diy repair if you feel confident ? the brushes in uk cost around £5 --£6 approx and to change them is easy by removing rear cover on machine you muat disconnect power/ drain pipe/ and turn off water supply pipe/s from machine ? the motor is rather like cars alternator in apearance?? disconnect power plug from it then you will have to look at motor and observe how it secures then remove bolts/nuts if you have new brushes to hand ??it will become obviouse how//where they fit and wire connects on each x2 at this it would be advisable after 5 yrs? to fit a new belt too? refit motor+belt adjust belt tension by adjusting motor on slide adjust then tighten? reassemble all parts in reverse then try a wash ? this is common prob especially after long time and for your info the down comforter load was the final nail in coffin but should have no probs after new brushes always think the positive waves! not the negative! good luck
Posted on Oct 30, 2008
Compressor won't engage-water was shut off and on to house when away-no symptoms before-
no you need a new ptc overload relay thats mounted on the compressor it aids in starting and running the compressor
May 12, 2012 | Kenmore Refrigerators
Fridge stopped working both freezer and fridge, Here clicking at compressor, compressor not starting, cooling fan and everything else OK, could it be the compressor or is there a chance the thermal switch...
This is a bad compressor, or overload-relay kit. Disconnect the power, remove the overload-relay from the compressor, and test the three compressor terminals for continuity . You should have continuity between each terminal, and you should not have continuity between any terminal and ground. If this tests ok, then replace the overload-relay kit. This is a common repair for me, and it is very rare for us to find a bad compressor, so you should be ok. If it is a bad compressor, and it is less than five years old, you have a five year sealed system warrantee, that will cover the repair cost. If it is over five years old, it is not worth repair. When you are done with the repair, make sure you install a 2000 joule or higher, surge protector to protect your refrigerator from this type of repair in the future. Good Luck, Appliance Specialists
Mar 14, 2011 | KitchenAid Superba KSRG25FK Side by Side...
THE REFRIGERTOR JUST STOPPED WORKING IT IS 5 YEARS OLD AND NOT OVER USED
The overload/start relay may have gone bad.
Other possible causes:
* Bad thermostat. Check thermostat
* Defrost timer. Not definite but possibly bad. Last resort.
*Concentrate on getting the compressor to run first.
Once the compressor runs again, observe the refrigerator for a while to confirm cooling.
If there is no cooling after at least forty five minutes, your refrigerant may leaked out.
Do not despair, get the compressor running first. The worst case scenario would be a burnt compressor, and that has not been established yet.
Dec 22, 2010 | Magic Chef MCBR440 Compact Refrigerator
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
Kenmore hum click sound
Bad overload relay or bad compressor. You can change your overload relay to test, usually fairly cheap, (55.00 from Sears) however if it is your compressor, it is out of it's five year warrantee and is not worth repair. 900 to 1100.00 to repair in my area.
Jan 18, 2010 | Refrigerators
Kenmore refigerator keepsgoing into defrost mode
Hi, If you changed relay, overload, & capacitor on the compressor and it still clicks on and off, the compressor has gone bad and will need replaced. Is this unit under five years old?
Vic
May 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a Maytag LAT9400AAW. I started a (large) load and it filled and started screeching and smoking. I thought the dryer was on fire until I unplugged the dryer and got behind it. I stopped the washer. ...
You have overloaded you machine. The sound you hear is the belt burning of the machine, Please limit the size of the loads and hope you did not do further damage to you machine
Jan 19, 2009 | Washing Machines
Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Nov 08, 2008 | PfaFF Sewing Machines
Own a Maytag Washing Machine Model No. LAT9416AAE I overloaded with a extra large comforter. I started the cylce and went upstairs to my room leaving it unattended. My parents were down stairs With it, and...
there is a thermal overload protector in the motor. After the motor cools it should restart. There is an off balance switch that might have been tripped when pulling out the comforter or when bailing out the water. As for the belts, tip the machine back and you will see the belts underneath the washer. Very easy to change and you'll see what I mean when you see the belts. That should solve your problem. AND DON'T OVERLOAD THE WASHER AGAIN.
Feb 27, 2008 | Washing Machines
Refrigerator humming noise and loss of coolness in freezer.
the relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Nov 27, 2007 | Refrigerators
Kenmore Elite 45986 Front Load Washer Logo
146 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
