Question about Toshiba MV13Q41 13 in. TV/VCR Combo
Colors are off
In the morning the tv was fine...wasn't on all day. In the afternoon, the colors had divided up. red on top green on bottom. we have had plenty of storms here and power outages repeatedly.
    President:
  • 3,130 Answers
Before taking the set to the dump, try to unplug overnight, not just a breif time. If that doesnt help you are going to need to have it serviced or replacement is most likly the outcome ,because of the proice its going to cost.
Posted on Sep 12, 2006
SOURCE:
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
The image is divide on three.red,blue,green. At first when on for the first 10 minutes it looked fine then the image diverged with the 3 colors. Now the image is divided in 3 colors all the time. What...
This most likely is convergence problem, see attached photo, do not pay for this help.
Set uses two convergence chips, they will need be replaced, less than 15 dollars for a pair.
If you are interested make a comment and I will assist you.
SD TECH
Aug 26, 2010 | Sony KP-61HS30 TV
Red Blue and Green?
All colors in a tv are made up of red ,blue and green,,. my projection in the menu has under setup,,just check for it,,its called conversion ,it realines the colors,, you have to do it periodicaly,or sooner if you move a projection tv,, thanks,, .it should have it,,good luck
Oct 05, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Toshiba MV13Q41 13 in. TV/VCR Combo Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
