Question about Philips 9P6040C 60" Rear Projection Television
Phillips Magnavox 60" tv
I have a Phillips 60" television that doesnt power up properly. Model #9p6040 c102. My initial problem was that the sets picture would be lost at random time intrevals and become a vertical white streak in the center of the set. After turning off the set and letting 1 hour or more pass the set would operate properly for a while then repeat. Sound is not affected. At one point I decided to unplug the set and give the interior of the cabinet a cleaning using light air pressure and a vacumn. Now the sets power indicator led illuminated green as it normally would and a small speaker 'surge' but no normal tv function. Also no screen indicator to enter menu options. Do you have any idea(s) on this type of problem and possible costs. I realize the set is 6 yrs.+. Thank You for your time.
  • Anonymous Nov 12, 2007
    same problem...my picture sometimes come on small and gets bigger until it fills the screen, sometimes takeing a lot of turning on and off....
  • Anonymous Jun 23, 2008
    We turned our television off for about 4 hours, came home and tried to turn it on and there is nothing. We tried changing wall plug ins, checked to make sure the power plug was in good and still it will do nothing. The DVD and satellite are plugged into the same power surge and they are working fine.
  • Philips Master
  • 3,459 Answers
If your video is shrinking and expanding its the opto IC. You can get a repair kit from www.magnavoxhelp.com
Posted on Jul 16, 2008
  • Edward
    Edward Jan 26, 2009
    Common problem and fairly easy to fix.
    Problem
    Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
    Solution:
    Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
    President:
  • 3,130 Answers
Your first problem sounded like a bad solder connection on the vertical circuitry somewhere on the nprinted circuit board. Now its almost anyones guess, as I dont have a clue what you moved or touched when you attempted to clean out the set. its a job for a pro if you have no TV repair experience.
Posted on Sep 12, 2006
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips Magnavox 9P6040-C101-60" Rear Projection Television
You can get a repair kit for the shrinking/expanding on www.magnavoxhelp.com. This is a common problem with this model.
Sep 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 9p6040
Sounds like a solder or connection issue on the small signal panel. which is the ciruit baord on the left hand side of the set looking in from the rear of the set.
Jun 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
9p6040 c102
Visit www.TvRepairKit.com for a repair kit. Its a common problem and an easy fix.
Jan 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
The picture is fuzzy and shaped like a hour glass
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Dec 02, 2007 | Philips 9P6040C 60" Rear Projection...
Philips Magnavox 9p6040 c102
IC's on convergence bd. 1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 search google to buy.Datasheets at datasheetcatolog.com
Nov 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
9p6040 c102 60" television - has power, no sound or picture
Screen shrinks and expands and wams up after 10-20 minutes and then went out completely? Power light still comes on and remote still works? This is a common problem for this model and is most likely related to a bad chip. A tech will charge you over $300.00 to fix it but you can buy the repair kit including the chip, step by step instructions and repair manuals for under $40.00 if you are willing to do a little soldering. Go to http://www.magnavoxhelp.com/ and enter your model or chasis number and order the kit. This will not fix color problems!
Sep 20, 2006 | Philips 9P6040C 60" Rear Projection...
Philips 9P6040C 60" Rear Projection Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
