Ricoh Aficio 1232c copier error code SC571
Now I know This error code SC571 is for fuser oil level high code
some body in the shop has put oil to the tray. I drain the oil from the tray
and put oil in the container back of the machine. can some one tell me how to reset the code or clear the code, may be fix the problem.
Thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Enter SP 5-810 and set to 1, then switch off and on the machine.
Posted on Jan 10, 2009
  • wendyccollin Jun 02, 2011
    Where do you go to enter this?
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
How do I clear Fuser oil low message on Ricoh Aficio 1232C after refilling fuser oil bottle
At the machine. Press in this order. Clear all ( yellow button) then 107, then press and hold the pink stop button until the screen changes. You will see some icons that say Copy SP, Sytem SP.
Select Copy SP, if thats not available select System SP.
You will see several buttons. Select sp 7 Data Log, Then scroll to page 804 and select that. Then scroll to item 11. That is where you will select to clear the fuser oil count and reset it.
Jan 28, 2011 | Ricoh Aficio 1232C Color Copier
Appel service technique Ricoh aficio 1232C super G3. code SC571. j'ai rempli le réservoir de l'huile de vaseline d'après les forums.mais toujours le...
code 571 low oil top up oil located back of copier reset code press yellow key 1 0 7 press red
key keep held for 4 secounds go in copy sp press 5 press lower cursor key untill you reach 5 810
sc reset code then turn copier off/ on
Nov 08, 2010 | Ricoh Aficio 1232C Color Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
Mar 31, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Dec 15, 2008 | Ricoh Aficio C811DN-T1 - printer - color -...
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
2,248 people viewed this question
k24674
jasbo
jasbo
