Question about Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat room fails to recognize my Gigabeat
As above, the gigabeat watcher is green (ie the PC recognizes it) but the gigabeat icon in gigabeat room isnt working and hence I cant transfer music to the gigabeat! Am using Vista and it has worked before but now wont! Have updated version too (3.0).
  • Anonymous Dec 01, 2008
    Same issue as mentioned. Running Vista, my songs will play on the gigabeat, I can manually put mp3's onto the gigabeat and play them on the comp. running gigabeat room 3.0 but if I unplug the gigabeat from the computer they don't show up and I tried using the formatting utility and it don't recognize anything being used that can be formatted. please help.
    BCraven29@aol.com
  • Anonymous Dec 24, 2008
    same as above ..it was working and now its not
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Posted on Dec 29, 2008
Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Mar 30, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
transfering is not a a problem its a player problem have  you ever format your mp3 player?
Dec 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat F20 and Windows Vista
hi i had the same problem and updated gigabeat room to version 3 , not the actual gigabeat just its pc software , and it seems to work ok most of the time but only if i load gigabeat watcher after plugging in my player . hope this helps ,i emailed toshiba uk but they told me that they have no intention of updating the players firmware ,
Apr 07, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
I have a Toshiba Gigabeat F60 from several years ago. It stopped working shortly after I got it and now I would like to try to get it working again. Upon start up it says "no system found oh HDD" but my...
The Gigabeat is not recognizing the firmware on it. The easiest way to re-install the firmware is to install Gigaroom. It will be able to recognize the Gigabeat and replace the firmware.
Apr 06, 2008 | Audio Players & Recorders
Computer does not recognize Gigabeat Device
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Feb 28, 2008 | Toshiba gigabeat S MP3 Player
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEG-F20S MP3 Player Logo
441 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
