Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Defective Picture, Sound ok
Last week the TV would come on and perform normally, with ocasional flashes and problems as described below. Each day normal periods of good operation became shorter and shorter.
Now the screen comes on greenish color, w/poor detail. After a few minutes the detail goes away leaving a green, red or white screen. Sound good always. The tuner and video inputs both do the same. However the menu, channel number, and stereo/mono displays are always good.
The unit is 4.5 years old and has provided very good service.
Thanks, David Hauck, dd3834@earthlink.net
  • Akai Master
  • 19,396 Answers
It can be a problem with one of the sustain boards, or with the power board, or with one of the video signal board you should have it checked by a techincian
Posted on Oct 30, 2008
    President:
  • 2,712 Answers
You will most likely need both convergence IC's in your TV. Need a service call.
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
Sound , but no picture
It sounds like the problem is in the circuit board. The TV should go in for professional repair - electric shock is no fun. Good luck.
Apr 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
I have a VIZIO VO47LFHDTV10A that is less than 4 years old. Last week the screen went blank but the sound is OK. The sound is fine on all inputs but no picture. Another TV hooked up to the same power and...
Good day!!!!
If the reset is not work the problem could be the inverter board found inside the TV..
When you open the back cover of your TV by unscrewing it..After that the inverter board become visible.
This is the sample picture of inverter board:
After you replace that board your TV back to normal operation..
Hope it helps..
Nov 19, 2011 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Picture goes off, red light blinks 7 times, sound quality is not affected.
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Sony KP-53HS10 TV
I have wega KV-HR36 red light flashing 10 times
Sep 11, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
TP50F60/TP50F61 not working; no picture or sound;
Sep 11, 2009 | Toshiba TP50F60/61 TV
hi
i think its a colour wheel problem...if there is led blink tell me how many times it will blink i will sort if there is error code and i will tell the solution
Feb 14, 2009 | Sony Televison & Video
Black screen only on new LCD
Sounds like the video board when bad. I would say the TV went defective. Use the 90 day warranty to exchange for a new one.
Always use warranty at this point because the newer TV coming out in these days have very lame warranty.
Rate me, please
Feb 02, 2009 | Televison & Video
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
76 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
