My lower element on the oven cracked. I have a new part which I ordered and received in one day! Amazing.
Now, how do I change this thing.
Who Knew
SOURCE: Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: Gemini MER6769BAW Range/Dual Ovens
depending on type of unit. most of the time they are very easy to change out.. look at element locate two screws. go shut off breaker to oven.. make sure its has no power. after removing screws element should come out fairly easy.. make sure not to let wires fall back inside unit. if so not to worry. just pull unit out from wall and remove back panel. push wire back through. hope this helps
SOURCE: replacing a radiant element on
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
