Question about Lexmark X7170 All-In-One InkJet Printer
LOST i LOST MY USERS MANUAL AND NEED TO KNOW HOW TO RECEIVE A FAX i HAVE THE 7350 MODEL iM NOT SURE WHICH CORD TO PLUG IN WHERE HELP
  • ROSE_PORCELL May 11, 2010
    i LOST MY MANUAL
  • 385 Answers
Here's a link to the user manual for the X7350 printer. Hopefully, you can find what it is you are looking for.
Thanks,
Lolita
Posted on Oct 30, 2008
    President:
  • 2,712 Answers
You can download the user manual from here:
http://www.lexmark.com/publications/pdfs/2007/7300/ug_en.pdf
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Lost manual
Hi Carole. You can easily download a copy of the user guide by clicking on the following link, then entering your model number in the box.
http://www.bissell.com/user-guides/?cid=ccsocial
Mar 26, 2013 | Bissell 7350 PROdry Upright Steam Cleaner
The fax line rings and rings but does not pick up as a fax. Is this an issue with the machine or the phone line?
Most likely the machine. This is usually caused by one of two things. Either the machine is set to manual answer, therefor requiring the user to initate the fax reception or the modem has gone bad and is "deaf" to the incoming ring and thus won't answer. Also make sure that the phone caord running from the wall jack to the fax is plugged into the "Line" port on the back of the machine. It should NOT be plugged into the "phone" port.
The display on the machine should tell you wether it is in auto receive mode. You did not post your model but I would check the displey for the word "auto" or similar. If it says "manual" then that is your problem. On some models there is a receive mode light.
Check the phone cord to be sure it is in the line port.
Check the receive mode to be sure it is set to auto receive.
If you have your operators manual make sure distictive ring is turned off.
If all of these are ok then you may have lost the modem board in your machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 22, 2010 | Office Equipment & Supplies
My Dell Photo 964 All-In-One won't receive faxes, but can send them just fine. All other features are alright. Spoke to Vonage (our phone service) for 2 hours troubleshooting and sending test faxes, and it...
First check a couple of obvious things:
Sometimes the presence or absence of a (DSL) filter on the line can affect fax reception.
Also check to make sure you have not enabled Fax Blocking.
Otherwise, I can only offer some information HP provides for support of VoIP fax setups, available by clicking here., and hardware setup options available here. Whether it is even remotely useful in your situation you'll have to judge.
You know there is also a Dell Forum where users
can pose questions and exchange answers. Have you checked to see if there are solutions posted there? Dell Forum 964fax error
I'm afraid I am not familiar with that particular machine or Vonage...sorry I couldn't offer anything more...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
Setup
It should automatically default to AUTO RECEIVE. Plug the phone cord into the LINE port on the machine.
Dec 23, 2008 | Brother IntelliFAX 1840C Plain Paper...
I have my husband's Panafax UF 895 fax which I am using since my other fax broke. We set it up, but he can't find the manual -- I can fax out and copy, but can't receive faxes. On the display it says...
Your machine is set to Manual Receive.
You need to change Function 17 to 2.
Go to Fax Parameters on the below link to help guide you through programming the fax parameters.
Basically, you hit FUNCTION, then #7, Press #4 and Set,Enter 17, hit Set, enter 2, Set. After you are done, then press STOP, and your machine should be set to AUTO RECEIVE.
Here is a link for the user manual:
http://www.best4systems.co.uk/_design/best4systems/_pdf/Faxes/Panasonic/Panasonic_UF885_UF895_UG.pdf
You should probably save a copy of the manual on your computer incase the link is lost or shut down in the future.
I hope this helped.
If you have more questions, please repost again and remember to leave a rating if I have helped you.
Good luck.
Mac =)
May 02, 2008 | Office Equipment & Supplies
I bought philips faxjet 335, tx error
sounds like your communication board is out or your phone line is not working when you unplug your line and put a phone on it can you get a dial tone? then your fax machine is probably broke
Dec 14, 2007 | Philips FaxJet 375 Plain Paper Inkjet
FaxJet 335, tx error
call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer.
your timeout may be set too short on the sending fax setup.
Doesnt Know How To Use Fax
Very easy. Make sure you have a phone cord plugged from the wall to a port in the back of the machine marked "line". Place you document in the feed, dial the fax number of the other machine and press start. Your machine will dial the other machine, make some beeping noises then scan your document. If it feeds through ok, and you do not get an error message in the display, then it has been sent!
Jun 19, 2007 | Brother FAX-T78 Plain Paper
WONT POWER ON when plugged into a known good power source
This is from the FAQ on a similar model (the 770). My guess is that it won't be much help, but who knows... : The machine is not receiving a power signal. Make sure the power cord is plugged securely to the power outlet. If a surge protector or an extension cord is being used, disconnect them and plug the fax machine's power cord directly to the power outlet. If the fax machine is still not receiving a power signal, try plugging the machine's power cord into a different outlet on another circuit breaker. Good luck
May 19, 2006 | Brother IntelliFAX 775 Plain Paper Thermal...
Lexmark X7170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
