Question about HP Officejet 5610 All-In-One InkJet Printer
Does not print from pc
Pc does not recognize printer. 5610 stopped printing from computer. Tried to uninstall and reinstall several times. Printer shows in programs, but has no icon in printers and faxes.
Need software to install 5610 to pc
Posted on Oct 31, 2008
My printer prints qwith no reason hundreds of pages
Uninstall the printer and reinstall it.If you don't have the driver windows OS may recognize it depending on how old the printer is.Also the Mfg.'s website will have it
Feb 02, 2018 | Lexmark E260 Laser Printer
I recently downloaded the printer on my computer but when I try to print, it doesn't print the page centered. It prints to the left. We have this problem when printing from several computers. How can...
I suggest that you try to do a reinstallation as the PC and printer has not meshed up well. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Apr 04, 2011 | Ricoh Aficio SP C410DN Laser Printer
Printer isn't printing properly
your cartridges are goggled try cleaning them from maintenance menu of your printer
May 01, 2010 | HP Officejet 5610 All-In-One InkJet...
Computer not recognizing printer
Printers drivers will sometimes lock the queue. uninstall the printer from the system and reinstall. if you cannot reinstall and get spool errors try this:
hold the windows key down and hit r on the keyboard.
in this window type in cmd and hit enter.
in the command prompt type
sc config spooler depend= RPCSS
if you can't uninstall read this article to manually remove a printer in windows
http://support.microsoft.com/kb/324757
Feb 11, 2010 | HP Computers & Internet
I keep getting a Printhead missing, not installed correctly or has come loose error. I have tried reinstalling the print head, several times and powering off several times but neither help. Any...
HTML clipboardHi
Here are a few possibilities...
1. Try cleaning the contacts on the print head and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer... reinstall driver.
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Kodak ESP 5 Printer
Hp 5610 all in one printer, cartridge error, will not print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf17
Aug 10, 2009 | HP Officejet 5610 All-In-One InkJet...
WILL NOT PRINT COPY FROM COMPUTER TO PRINTER
To me it sounds like you may have to uninstall the printer software then reinstall it make sure mark that printer as your default printer .
Nov 17, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-IN-One Inkjet doesn't print
First of all, have you ever been able to successfully print using this printer? If so, my first question would be, what has changed recently on the computer and/or printer that might have contributed to this problem? If you connected another device to the computer recently, it may somehow be interfering with your printer, either because of the physical hardware connection or because of the new device's drivers.
If you have never been able to print using this printer on this computer, the first thing I'd look for is what you looked for...connection problems. If everything is plugged in correctly, another issue might be a bad cord. Assuming the printer is powering up ok, you can rule out a bad power cord. If you are using a USB connector to attach the printer to the computer, check and see if the cord is damaged. It's very common to roll over a cord with your chair, damaging it. Even if it doesn't appear damaged, see if a replacement cord will work.
You could be having a problem with your drivers. You can try to uninstall and reinstall your printer on the computer. This will require the original driver disk that came with the printer. To uninstall the printer, you can follow the steps on this HP.com website:
Uninstalling Software in Windows
Of course, I'm assuming you are using Windows and probably Windows XP, since that's the most common choice, but I could be incorrect.
You can get all the uninstall and reinstall information on the following web page:
Setup and Install
Have you tried printing a test page? If not, see Step 2 of the instructions on the following page:
Wrong Colors
Printing a test page is a good way to see if the issue is with the printer or the computer/application. You might also want to try to print different documents created with different applications (Word, Excel, PowerPoint) to see if they all don't print or only docs from one application don't print.
Please reply with your results after you've given these troubleshooting steps a try. Good luck.
Sep 21, 2008 | HP Officejet 5610 All-In-One InkJet...
HP L7680 stopped printing
if you still have the software completely uninstall the software and drivers and reinstall. go to the hp website and see if there is any updated or fixes for your specific printer. let me know how it works out for you.
Feb 26, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
65 people viewed this question
Ben Johnson
