Question about Maytag PAV2300 Top Load Washer
Will not spin
On my Maytag PAV2300 top load washer. It fills with water, it agitages, it drains the water. But, it will not spin. I have checked switch on the lid and that is not the problem. What should be the next thing that I try to check. Ap
  • anninoz Nov 26, 2007
    I have same problem with PAV3200AAW in Australia dont know if this is same washer?
    President:
  • 878 Answers
Ap, start with the tub and basket, make sure there isn't anything caught in between preventing it from spinning. Im assuming you already checked the belt. Next would be heavy duty stuff like the thrust bearing and brake. The brake may not be releasing. You can check this by turning the pulley counter clockwise slowly and seeing if the transmission spins. If not, the thrust bearing and brake may be bad. There was a number of service flashes out on this model concerning the thrust bearing, transmission and seal kit, vibration in spin and snubber kit. These things may be covered under warranty. In the event it's your transmission, it has a 5 year warranty on it....Catriver..post back.
Posted on Sep 11, 2006
On Maytag top loader, water enters but drains immediately.
check that the drain hose is above tub level
check for faulty program board engaging the pump all the time
Sep 20, 2016 | Maytag PAV2300 Top Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Washer fills with water, but before it begins to
drain hose is siphoning. pull most of it out of the drain and secure with tie strap.
Jan 18, 2010 | Maytag PAV2300 Top Load Washer
Leaking water for washer machine
Check your drain, drain hose (make sure the clamp is tight) and check the pump to make sure that all hoses are attached properly
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
270 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
