Piva ptv1502 screen keeps cutting off while playing can you fix problem?
    Problem Solver:
  • 8 Answers
If it's a V-Chip, Parental Control issue, here's the solution. Make sure RF coaxial cable is connected to TV. Press "V-Chip Menu" on the remote. On Password, press "Enter" on the remote. In Password, enter 666666, then press "Enter". Scroll down to "Modify-PW" by using CH+ or CH- key, then press "Enter". Enter 000000, then press "Enter". Select" V-Chip Menu" to exit V-Chip. Select V-Chip Menu again. On "Password", press "Enter" key on remote control. Enter 000000 in "Password", then press "Enter". Scroll down to "V-Chip", press "Enter". TV should display a list of all TV ratings. Use CH+ or CH-, scroll to TV-Y. Then press "Enter" key on remote. Be sure that all ratings are set to "On". Repeat the steps above and set all ratings to "On". Then select "Exit", press "Enter". Press V-Chip Menu" to close on-screen menu.
Posted on Apr 13, 2009
My lg p705 playing up now won't let put pin in so can use phone, keeps freezing n cutting out how do I fix it
go into your app manager and see what is running there, too many background apps can slow your phone down. Your DIGITISER glass screen may also be damaged and not reading touch correctly, looks like a job for the repair shop to test.
Jan 15, 2014 | LG P705 Optimus - Black
Youtube keeps cutting out on my android tablet .it will play for 1 minute then cut out , then resume playing then stop , then start, how do i solve this?
if you haven't rebooted your device lately try that first but most likely it's a buffering issue caused by slow service which you can't fix
Nov 07, 2013 | YouTube Videos
My ipod model a 1285 keeps turning itself off why
iPod keeps turning off Plug your iPod in overnight to make sure it has charge. If after a full night of charging it has a low battery, there is probably something wrong with your charger cable. Replace the charger cable, especially if yours is old or has ever gotten significantly dirty. Reset your iPod. This basic reset does not remove any content from your iPod. Apple suggests this soft reset as the first fix for any software problems or if the screen freezes. Eject your iPod from your computer first. For an iPod with a click wheel, toggle the hold switch on and off several times, then hold down "Menu" and the center button at the same time until the Apple logo shows up on the screen. For touchscreen iPods, hold down the "Sleep" button at the top right until the Apple logo shows on the screen. Perform a factory restore on your iPod if the previous steps do not fix the problem. Plug it into your computer and open iTunes. Click on your iPod, then click "Restore." This wipes all content from your iPod and re-installs the operating system.
b> iPod Keeps Cutting Off b> Your iPod may cut off during a song or video, or during an application. Different causes lead to different types of cutting off just the sound may disappear, or you may suddenly experience cutting to a different screen. For example, if your iPod cuts off during a song, you may have merely hit the "Pause" button. With a blank white screen, you're encountering a software problem. Whatever the reason, follow some simple troubleshooting steps before contacting Apple's customer service.
Headphones Check that your headphones are connected correctly if the sound cuts out suddenly. If the 3.5-mm headphone jack comes out even a little bit, it can make the sound cut out in one or both headphones. Check for debris in the headphone jack itself, which can prevent a solid contact between the headphones and the iPod. b> Other Sound Issues b> Make sure the volume is up high enough. Also, especially if the iPod is in your pocket, make sure you haven't bumped the pause or sleep button. To ensure that audio plays constantly, engage the lock on your iPod. The music will always stop when you pull out the headphones, and once the headphones are back in, you have to push "Play" again. Cutting to White Screen b> A sudden white screen may appear when a generic software malfunction occurs, one in which t you don't get an error message. You must reset the iPod by turning it off, then on again. If this happens several times and you are using the same application each time, that app may be faulty. Try re-installing or re downloading the app. b> Cutting to Black Screen b> An iPod that cuts out to a black screen and won't turn back on is usually out of power. Usually you'll see a low battery warning, but if you're not looking at your iPod when the warning flashes, you might miss it. Once you connect your iPod to a functional power outlet, you can turn it on immediately, but it's best to wait a few minutes when the battery is very low. This gives the iPod a chance to regain power so it can function normally when you plug it in. Hope it helps.
Jan 22, 2013 | Apple iPod Audio Players & Recorders
MY SONY DCR-SR190 HDD CAMCORDER LCD SCREEN KEEPS CUTTING OUT, IT
mine started like yours then stopped working at all .It's a flex wire that connecting LCD with camcorder. it's very common. I did by miself, bought it in repair shop. works like new. mine is DCR-SR32 wire is 1-871-457-11 known as 1-871-457-21
good luck.
Meggita
Aug 16, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
Screen cutting in and out
By cutting out doyou mean.... The screen goes blank, but the sound continues to play? The whole deck cut's out,and then comes back on?
If it's just the screen it's self that cut's out, and the sound keeps going, you are dealing with an internal issue.
If you deck loses power, and comes back on, then you are most likely dealing with a wiring issue.
Aug 08, 2009 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
Torubleshoot
how to fix a power supply if the white copper is no power
Jun 21, 2008 | Computers & Internet
PC Input Cuts out after DVD starts playing
Try another DVD disk. If this does not work, then it is possible that the drivers became corrupt, or the drive, or the controller has gone defective.
You try uninstalling the drivers and the drive for the DVD drive, and then re-installing them back again.
Jerry G.
Dec 24, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
