Question about Panasonic TH-42PZ700U 42 in. Plasma Television
Picsellating problem. When a light is turned on or off anywhere in the house, microwave cuts in or out, another appliance is turned on or off, indeed any other electrical device is used, areas of the picture breaks up, albiet small areas and at the same time the sound dissappears.
  • 20 Answers
This is not really my area of expertise, but i would venture to say it has to do with your neutral wire in your outlets. If your house is older, the neutral, which is tied to the ground in the panel, was not sized to hold the modern electronic equipment. WIthout getting to technical, electronics create what are called noise and harmonics on electrical wires which is the static or "breaking up".
A larger neutral should fix it but that would involve at least rewiring that outlet with a straight shot to the panel and maybe upsizing the neutral in the panel. I would get an electrical engineer or someone who has worker with a lot of electronics opinion beofre you go to crazy though. A straight shot cable from your tv outlet to the panel should fix it though, i would bet.
Posted on Mar 31, 2009
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
Hi when the philips bluray player is playing and someone switches on a light switch or appliance anywhere in the house the bluray player switches off for couple of seconds and then turns back on any idears...
The voltage of the mains in your house is very low and when another appliance is turned on and the current it draws during the startup procedure is very high it drops below what your player can use - so it simply shuts down. When the appliance goes in normal mode the current drawn drops = the voltage goes up and you player restarts. Verify the voltage settings of the player and, if necessary use an UPS.
Oct 27, 2010 | Philips Televison & Video
GT-11 Lights up when near my granite counter top ????----Also Nearly All Electrical Metal Items In House----When We Unplug Microwave Granite It Stops Showing Voltage ????----RICK
Grnite is SLIGHTLY conductive so if your counter top goes anywhere near live wires such as an appliance, you may sense it is hot with thaat detector. The stray field from the microwave is jumping onto the granite... HOWEVER please verify that your ground on the microwave is intact and returns to the third wire and has continuity to the case of your breaker box. If the ground is broken, that will certainly cause the indication. You can get one of those receptacle testers to test this.
ALSO NEVER trust the detector when safety is an issue. The device is "indication only" and it can be wrong for various reasons.
Sep 06, 2010 | Greenlee GT-11 Non-Contact Voltage...
The power cuts off after 2 minutes of cooking. The microwave doesnt turn back on for ten minutes.
There is an automatic circuit breaker that it tripping. One of two options
1) Something in your oven is either malfunctioning (difficult to find and replace). It is likely better to just replace than pay to have it fixed.
2) The house circuit that you are using is not providing enough power to the microwave. Check if something else is connected on the same circuit. A microwave runs poorly when not getting the full 115 volts that it was designed for and may fall into a safe mode and shut down for a while.
Newer houses should have the microwave on a dedicated circuit and should not have this problem - I say should not because electricians can make mistakes too.
You can try to trip your microwave circuit and see if anything else stops working. If so, that is likely why your microwave is falling into a safe mode - it is not getting enough juice.
If you have an older home (pre 1995), try to find what else is on your microwave circuit by tripping the breaker as listed above, then not using the other appliance when using the microwave.
Good luck.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The internal light on my combination/microwave oven (HME9750) is no longer working. I can't see where the light fitting is, nor how to access it. Is this something that I can replace without major problems...
IF YOU TURN OFF POWER TO APPLIANCE AND WITHDRAW IT ABOUT 4 INCHES FROM HOUSING LOOK AT THE TOP YOU WILL SEE A PANEL WITH 2 SCEWS UNDO THIS TO SHOW BULB UNSCREW REPLACE AND REASSEMBLE.
Oct 19, 2009 | Bosch HME9760 Microwave Oven
Flickering lights
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 24, 2009 | Samsung MW5351G Microwave Oven
Microwave/small appliances do not turn on when plugged on to the power outlets on one wall.
What does "control panel has all fuses working" mean?
Are you saying you have an old-fashioned fuse panel in your house, instead of a modern circuit breaker panel?
If so, then I would suspect a bad connection in the panel.
If you indeed have breakers, a breaker can snap into the on and positions and still be bad.
Either problem sounds like it should be handled by a qualified electrician.
The power company or your insurance company would likely reimburse you for all or part of the electrician's bill, but you shoudl call first to be sure.
It's possible to have a faulty neutral connection in your wiring. That can lead to damage of several appliances and bulbs, and even pose a real fire or smoke hazard.
Please do not hesitate to get things fixed when you have home electrical problems!
Nov 04, 2007 | Samsung MW5351G Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
