Question about Motorola Mobility H500 Wireless Headset
Need a passkey
Have not used the device in a while and now when i try to use it i need a passkey
  • 488 Answers
Usually its four zeroes 0000..did it work?
Posted on Nov 02, 2008
I do not understand what this passkey for bluetooth connection is. I don't have a bluetooth headset but im trying to pair my samsung highlight with a samsung messenger 2. I have already tried the four...
Step 1
Check your device for a sticker with the passkey printed on it. Typically headsets and car stereos have the passkey printed on a small sticker attached at the rear of the device.
  • Step 2 Look in your device's instruction book to see if the passkey is written inside. Each device has a unique passkey, so the passkey for your device will typically be printed on a sticker or inserted into your instruction book, as opposed to in the directions themselves.
  • Step 3 Check the Bluetooth menu for your device. Cell phones and computers often have their passkeys within the Bluetooth menu. Look for the "Pairing Code" or "Passkey" option. Some laptop computers generate a random code each time you need it, so you may have a option for this task.
  • Step 4 Check in forums for your particular device to see if someone has posted the passkey. Typically a search for your device and "Pairing Code" will bring up information regarding the code or where you might successfully find it.
  • Step 5 Call customer servicemag-glass_10x10.gif for your device if you can't find the passkey printed on the device, in the instruction book or in the menu. Customer service should be able to either tell you the passkey for your device or give you detailed instructions on how to find it.
  • Mar 05, 2010 | Samsung Highlight Cell Phone
    Need passkey for Motorola H371
    Pass key is nothing but a security key which u give to your device
    For exampe: use 1234 as passkey and use the same key on other device in this way you can pair your devices.
    Dec 28, 2009 | Motorola Cell Phones
    Have a dell studio 1555 with bluetooth configured into the system. Have tried sinking a Palm phone using 0000 and 1234 as passkeys when requested to provide one , but neither passkeys have worked. Are...
    I would recommend calling the manufcturer and explaining the issue. They should be able to reset the passkey for you and give you a default one.
    Nov 08, 2009 | Dell Studio 15 Laptop
    Trying to sync with my blackberry 8900 asking for numeric passkey for my plantronic 220 ... dont think I needed this when I had a Motorola Razor.... annoying.... any thoughts.
    the passkey is just like a password which is a single time entry into your phone for connecting blue tooth devices in a secured way.
    once you enter the passkey the phone will be able to identify and connect to your device each time you search for blue tooth devices in the phone.so please do not get annoyed, go ahead and give a passkey of your own choice(like birth date. so that you wont forget it easily since you wont use it again until you reset the phone or connect other devices).
    this passkey can also be used to connect it to laptops, desktops if they have blue tooth.
    also remember this passkey is used to restrict any unauthorized access to your phone.!!!
    should you have any questions please write to us again.thanks for contacting fixya !
    Oct 23, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    Blue tooth connection passkey
    Most Bluetooth devices uses '1234' or '0000' as the default passkey. Since you tried using '0000', you may wanna try using 1234.
    Have a great day!
    May 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
    How to get a bluetooth passkey
    hi there,
    if you are pairing the bluetooth headset device with your cell than the default passkey is 0000 (you can also check the user guide for bluetooth headset). and that will work with your phone.
    if your pairing the phone with other phone then you need to create your own passkey to pair it with other device (try 1234) and the same key you have to write on other phone once you will do that your phone will be paired and you are able to use it.
    i hope it will help you.
    best of luck
    Mar 23, 2009 | LG RUMOR Cellular Phone
    LG HBS 200 connection to the computer
    the default passkey is 0000. try it and see if that works.
    Feb 26, 2009 | LG HBS-200 Bluetooth Headset
    Need Bluetooth passkey
    a passkey is just a normal inserted between two bluetooth devices to connect them securely.
    Let it four times 0000 as your passkey
    Feb 17, 2009 | Motorola Mobility RAZR V3
    Im trying to set up my bluetooth on my cell phone. It finds my bluetooth an H700 motorola then I press pair and it says to ENTER PASSKEY, I dont know what it is. I tryed 1234 and it says failed to...
    passkeys should be entered for both devices.
    like when you are trying to paired your phone with you friend's
    it would then asked to type in a passkey, you can type in any passkey you like but it should be same combination with your friend's. (so you can use 1234 punch in on yours and your friends need to use 1234 code punch in his phone, so both bluetooth device will be paired successfully).
    Apr 28, 2008 | Cell Phones
    Passkey
    The passkey for Motorolla bluetooths is 0000
    Mar 25, 2008 | Motorola Mobility H700 Wireless Headset
    Motorola Mobility H500 Wireless Headset Logo
    27 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Coss
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
