Brother DCP-135C MAGENTA not printing tried cleaning as per menu 4 times but still not printing. Have tried 2 new cartridges but as made no difference
  • 2 more comments
  • Anonymous Nov 24, 2008
    I have the same problem with CYAN blue. I have followed the manual meticulously. I have gone through the head cleaning exercise X 4 and then the ink replacement process three times. The last time I replaced all the inks, but still the blue will not print.
    has anyone any thoughts?
  • samanthab1 Jan 12, 2009
    I just replace the black and the color cartridge in my d135, but the magenta isn't printing. I've cleaned the printheads twice, but still no magenta. Anyone been able to fix this problem?
  • luaep Jan 17, 2009
    I have the same problem.  After replacing the ink cartridge for magenta, it cannot be printed.
  • Anonymous Apr 13, 2009
    I have the same problem, I replaced all ink, all color printed except black
What you have to do is flush the head externally, then get an eye droper remove the plastic spout ,now you will only have the rubber resivoir. squese the rubber and place over the print head . when you release the rubber your creating a vacume wich will draw out the dried ink. repeat about 5 times on the entire head then flush with cartridge flush .....pretty messy so have lots of tissue paper and gloves.
reasemle head and case run the cleaning process 3 times and you will be smiling.
ps make sure you have lots of ink in your cartridge or you will have to redo the process again.....good luck
All Brother printer have this problem with the red ink.
Posted on Apr 27, 2009
Can someone have a video or somethink so show how to do this please..?
Posted on Apr 03, 2013
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
Brother DCP-135C Every time I switch on the printer, I get "Cleaning Cleaning Cleaning" for about 4 or 5 minutes before I can print anything. It's driving me potty. Is there a fix for this before I chuck...
try these options below....
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. another thing might be that you have to leave the printer on at all times, have you've tried this? i have known printers to be this way, not so sure with your brand though.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP-135C won't print yellow
1 years?
Means still under warranty for print head. maybe print head faulty. Better send to Brother.
Jan 27, 2010 | Brother DCP-135C Flatbed Digital MFC...
The colour on my Brother 135C Printer is not printing properley, could it be that the printer heads need aligning? If so how do I do that? Regards, David Melton
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother DCP-135C Flatbed Digital MFC...
I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Dec 19, 2009 | Brother MFC 420CN All-In-One InkJet...
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
Jan 17, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-310CN Magenta not printing
Hello!
Here is the manual to this device.
Please check the troubleshooting part. Hope it will help!
https://manualsbrain.com/en/products/brother-dcp-310cn
Dec 07, 2017 | Brother DCP-310CN All-In-One InkJet...
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
2,023 people viewed this question
jasbo
jasbo
