Question about IBM Wheelwriter 30 Typewriter
Ribbon has been replaced now won't type
The ribbon was replaced but now the machine will not type. the character wheel doesn't extend to strike the paper. what do we do?
  • IBM Master
  • 3,594 Answers
The most likely problem is the plastic cap in the print solenoid plunger is broken they are available but a little tricky to install. The soleniod is round and just inside the l. printer side frame.
Posted on Oct 30, 2008
Printing on the top half of the characters
Is your platen snapped down all the way? Can you look at the ribbon and see where the letters are striking the ribbon?
Apr 01, 2014 | IBM Office Equipment & Supplies
I have a Canon StarWriter 30 that I bought ~1995. I rarely use it, and have kept it in mint condition. I just tried to type something, and found that it's not printing the full characters; it's cutting...
Check that the hammer is striking the letters squarely, that the daisy wheel is firmly located in its holder , Check too that the patten has not moved up in its location. Check that the ribbon can still transfer a deposit across its entire width. (Look back at a used part of the ribbon to see the strike pattern).
Feb 10, 2011 | Office Equipment & Supplies
Nakajima ae-710 does not give a clear print. I suspect the striker pin. How do I lubricate it?
You should not have to lubricate the "striker"....type some characters then remove the ribbon cassette and see if the characters are spaced properly or are typing on top of each other on the carbon ribbon. You may have put the machine into a "multi-strike" can get a manual at
Nov 16, 2010 | Nakajima AE-710 Typewriter
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting
Apr 08, 2010 | Brother EM-530 Typewriter
Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
Feb 17, 2010 | Royal Office Equipment & Supplies
Typed characters are too light
Most Brother portables have a coded feature to change impression. Look for the word imp printed on one of the keytops, usually the I key<Hold down the code key and then depress the imp key to cjange the setting.
Jun 19, 2009 | Brother ML-500 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Feb 27, 2009 | Brother Office Equipment & Supplies
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Characters fill in intermittently.
This is a common problem with old supplies stored in a humid environment. Try leaving ribbon in an air conditioned environment for a couple of days to see if it helps. Otherwise buy a new sealed ribbon to try. Also push the hammer buy hand and see if it moves in and out freely and quickly. If not, the hammer needs some lubricant and or adjusting.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
75 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
