Question about RCA M100256 256 MB MP3 Player
Will not turn on or work when plugged into computer
I purchased this unit one week ago, i have downloaded music on it already. i was downloading some more music onto it, everthing was fine, i looked down at the unit and the screen was blank and i could not get it to turn on or do anything! is there a way to reset it or to fix this, i would be very greatful for a solution! thank you in advanced
  • 150 Answers
SOURCE: rca mp3 520 jet
Try a format - The below was copyed from an earlier post of mine. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Posted on Sep 17, 2007
  • 13 Answers
When RCA first came out with the Lyra series the only way to get music1.gif onto the device was by using musicmatch jukebox that would convert your mp31.gif file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support and find your player and download the firmware and drivers (if needed) upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma1.gif at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Posted on Feb 04, 2008
SOURCE: Can't download music onto my tc1500a rca mp3 player
thank you for your comment this way I got the information i had to reset my lazer mp3 player because when i unplugged the usb and tried to on the mp3 player its screen just blinked but now i reseted even unplugged and plugged so i reseted while it was plugged to usb so now it works again :) I lov you :D
Posted on Mar 10, 2008
  • 8596 Answers
SOURCE: RCA OPAL M4008 screen is blank and now it won't come on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 29, 2008
  • 1285 Answers
SOURCE: cant transfer limewire music from my computer to my mp3
go to my computer open the c: drive, then find the file that you had save your music. and open that file....connect the mp3 player (brand, model) to pc once connected open mp3 (copy music files from c::, paste all to mp3)
if your mp3 is an ipod you must download itunes and dowload the music from c: using itunes
have fun enjoy
feel free to rate
Posted on May 19, 2009
  • 2335 Answers
SOURCE: frozen at the opening screen, can't be detected by the computer
Actually, the firmware software will fix your Pearl even though the computer won't detect it right now. It worked for me and I've fixed my sony phone the same way. Try grabbing the latest firmware here:
And make sure you follow all the directions that popup, including removing the battery, holding play when you plug it in, and formatting the data area.
Posted on Sep 18, 2009
0 characters
1 Points
I have a new laptop... I am trying to download music from my computer to my ipod. I think I am missing some kind software to make this happen.
If you do not have iTunes already downloaded onto your new laptop then you need to download it before you can put music from your computer onto your iPod.
Go to this link to download iTunes (free). Once it is downloaded, you have to import your music that's on your computer onto your iTunes. This will take a while if you have a lot of music.
After that is done, you will be able to plug your iPod into your laptop and iTunes should recognize it and from there you'll be able to put your music onto the iPod.
Remember though, after you format your iPod to a PC you cannot plug it into a Mac (or Mac then to a PC) to put music on it, as it is already formatted to one and if you want music from the other you will have to reformat it which causes you to lose all of your music currently on it.
Be sure that the computer you are formatting it to (PC or Mac) is the kind you will be using for music at all times.
I hope this helps :)
Nov 14, 2010 | Apple iPod nano
Need a owners manual for a Apple Ipod Model 8GB
when you hold the power button (top left) down untill the slide bar with power down shows up, then slide the slider your ipod is fully turned off. as for downloading music you already have... dont you already have it? if you purchased it under your itunes store name then yes. you can re-download as much as you want.
Apr 15, 2010 | Apple iPod touch
How to download music from my pc to my ipot
You should install iTunes from
Then plug in the MP3 player, and once iTunes finds the device, add music to it from the library you already have, or by purchasing music from the Itunes Music Store.
May 21, 2009 | Apple iPod nano
Sansa clip mp3 1GB problems
the best way to solve the problem is to return it to the store! let the sudisk solve the problem and only after that to sale them
Mar 18, 2008 | SanDisk Sansa Clip MP3 Player
Jan 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Seeing & modifying contents on the mp3
Try; plugging your mp3 player in, open My Computer, then open a folder named Sansam240 or something, go to the folder you want to edit eg.Music.
Dec 23, 2007 | SanDisk Sansa m240 MP3 Player
Sansa 250 - Having problems downloading music?
You could try opening the folder(s) with your saved music and highlight all the ones you want to transfer to your mp3 player and then right click on one of the highlighted files, left click on Copy, then go to My Computer > Sansa e250 mp3 player should be listed in there, double click on it, then right click in a open white area and left click Paste. It should copy the music right to your player. You could also try using Rhapsody and import your music into it. I use Rhapsody for transferring music to my e250 Sansa mp3 player.
Nov 07, 2007 | SanDisk Sansa e250 MP3 Player
Ipod shown in recovery mode when plugged into new itunes version
Each iPod usually only syncs up to 1 computer. try downloading a program called idump. It allows you to take all of your music and files off the ipod and onto the computer, without having to restore. Then you'll have to restore the ipod, and put all the songs back onto it.
Oct 29, 2007 | Apple iPod nano
MP3 screen says 'NO FILE" when trying to listen to music.
try putting the music back on. if that dont work, all i can say is i hope you saved a receit
Aug 27, 2007 | GPX MW3836 MP3 Player
Computer Won't Recognize Device
Try plugging your USB cable (attached to your player) into the computer before you turn the computer on and boot up . . . I had this same problem with a flash drive that the computer would not recognize if I plugged it into the computer while the computer was already on.
Aug 21, 2007 | Mpio FY500 MP3 Player
RCA M100256 256 MB MP3 Player Logo
15 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
