Question about Garmin GPS
I bought a Garmin Zumo 550 from Amazon and the base plate will not work. Can't charge the battery or down load maps onto the GPS. Is there something I can do to fix this problem?? Thanks, Linda D.
  • Freefallun Oct 30, 2008
    Thanks IrishDruid,
    I just contacted them and they are going to replace the power cord, seems that was the problem all along. *Whew* Sure glad it wasn't more serious!!
    "Thanks so much"
    Linda D.
    President:
  • 2,712 Answers
You best contact Amazon and get the product replaced, before trying anything. They have a replacement/redund policy. I think that would be the smarter way to go. After all, you did pay good money for it!
Posted on Oct 30, 2008
  • Swilin Sampson
    Swilin Sampson Oct 30, 2008
    Most welcome, and glad I could help!
Paid for maps wont download
Contact Garmin directly and ask for a CD version to be mailed to you.
Feb 26, 2014 | Garmin zumo 550 Motorcycle GPS Unit
HI I have Zumo 550 when I first switch it it comes up with can't maps press OK you press OK then starts to work but starts at 1am on the clock and in night time mode after awhile it goes to the right time...
If your zumo 400 or 500 series will not power on, or performs strangely after powering up, follow the steps (described on the Garmin website) below to perform a soft reset:
  1. Connect the zumo to a power source such as a computer or AC outlet
  2. Hold the zoom (+) and ON buttons at the same time for five seconds
  3. If this does not restore power, remove the battery for five seconds
  4. Place the battery back in the zumo
The zumo will now power on. Because the battery may deplete while the zumo is locked up, it is ideal to leave the zumo connected to power to allow it time to charge.
Once the battery has charged, follow the steps on the Garmin site to update the operating software in the zumo. (just copy this link to get there https://buy.garmin.com/support/searchSupport/case.faces?caseId={8576ba20-e948-11dc-d6fc-000000000000} )
Good luck,
Michael
Feb 01, 2011 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Jan 09, 2009 | Garmin zumo 550 GPS Receiver
Garmin 550
Remove the battery an leave it out for about 10 minutes, then put the battery back, should startup....Oh yeah, if you have an sd card installed remove it.
Sep 14, 2008 | Garmin zumo 550 GPS Receiver
Zumo won't power from either cradle
Connector block at the base is stuffed. Needs to be replaced.
Aug 15, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 cannot find satellites
I'd remove the battery first, leave it out some time, put it back, fully charge it and use webupdater to see if all is up to date. There is a test menu on the Zumo to see if all works. I will tell you how to get there, only after you have tried the above first!
Jun 16, 2008 | Garmin zumo 550 GPS Receiver
No road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
Zumo 550
my battery failed after less than a year of use. Garmin sent me a new battery and the unit is working fine now. The old battery would not provide ANY power to the unit.
Dec 13, 2007 | Garmin zumo 550 GPS Receiver
Lines Running North and South
How do you load maps? and are these Garmin maps. I try to keep the Zumo original and use an SD card for extra maps. Did you try this yet? And if you are using SD cards, try a different brand/quality. I had some lockups with crappy budget cards. Kingston, Sandisk and some other A brands work fine!
Oct 16, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550
You'll have to select the europe map and deselect the usa map. Also you might have to change the locales. to do the first thing
tap wrench/tap map/tap about there you should see both maps, select the one you need and return to the wrench menu, select locales slect change all and walk through the menus (especialy the country!!!)
Aug 18, 2007 | Garmin zumo 550 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
