Question about Bunn VPR Coffee Maker
It fills the pot very slow - how do you clean it?
When we pour the water in and the coffee starts filling in the pot the flow is very minimal - slow. How do you clean these?
  • sstigger Nov 12, 2008
    I appreciate the help but yes there is a holding tank with water that is already hot - that is how you get coffee in 3 minutes. I cannot put CLR in because it will be in the holding tank too long.
    Problem Solver:
  • 7 Answers
Please remove the brew basket then spin off the 6 hole spray head... soak it in Citric acid,vinegar or clr. Also check the holes are clear from lime stone... If the tank is limed up you make need to remove the top nuts and syphon tube<<< check the tube for narrowing inside due to hard water buildup...Also check inside the tank resevoir for loose scale and remove..soak the inside of the tank with a solution mix of clr or citric acid and hot water for a time.... rinse well then reassemble.. NOTE: It is advisable to replace worn gaskets,seals, themistor and check the thermostat for correct funtion. Also , if you can get a deliming spring... you can sometimes loosen the particles inside the tube and outlet of the tank...when done using these springs please run one clear opt of water through the unit with the spray head removed to ensure all particles ar out of the the tube and will not repl,ug the spray head... when done replace the cleaned sprayhead, let the machine reheat and have at er!!
Robb
Posted on Dec 09, 2008
  • troy Dec 09, 2008
    Forgive my typos please...type way too fast..lol
    Robb
    Scholar:
  • 120 Answers
Hello tigger, You should be able to get a ipe cleaning brush at a fish/pet shop. Then apply it somewhat like this http://www.youtube.com/watch?v=CJSh1f6KHWw
i look forward to your post.
Posted on Nov 12, 2008
  • Eeeeeeeeeekz Nov 12, 2008
    CLR is good but make sure you flush it real good before you start drinking the water (hense its poisoness)
  • 42 Answers
There is also some chemical to flush thriufh a cycle called C.L.R. IT IS FOR CALCIUM LIME AND RUST ALOT OF HARD WATER DEPOSITS COME IN OUR DRINKINK WATERS.THE USE DISTILLED WATER AFTER YOU ARE FINISHED AND IT WILL NOT CLOG AS FAST
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Short pot of coffee
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Mar 09, 2014 | Bunn VPR Coffee Maker
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
BUNN VPR commercial coffee pot, not flowing in a steady stream just dripping
Your spray head has 5 to 6 little holes depending on the model and year, and it looks like you have scale, calcium or lime blocking them.
Since your model is a VPR pour model, you will have less trouble cleaning it with white vinegar than the permanent water connection type. I use a gallon of vinegar and filters for this.
Parts needed:
2 Clean, Rinsed Empty coffee cans
1 Gallon of White vinegar
5 coffee filters
1 Toothbrush, preferrably angled head
Start with your Bunn turned off and place an empty full size coffee can under the pour spout. Now place a filter in the brew basket to catch any fine particles you don't want poured back in the resevoir and heater. You will need to change this filter a few times as the trash starts coming out of your spout.
With the coffee can, brew basket, and a fresh empty filter in place you want to start pouring the vinegar in the tank while catching the water with the coffee can. As it fills with water you will need to dump the can down the drain until the full gallon of vinegar has been poured in the Bunn. Allow the excess water to finish flowing out into the coffee can making sure to leave half the water in the can to pour back into the coffee maker.
By now your tank should be filled with mostly white vinegar, and your coffee can should be at least half full of vinegar as well.
Now you can turn on the lower pot warmer to keep the solution hot and plug your Bunn into the outlet.
Allow 8 to 10 minutes for the heater to heat up and pour the half full coffee can of vinegar into the fill area. Allow the cycle to complete and replace the filter as needed, or if flow begins to slow down.
If your heads are clogged, use the toothbrush to clear the holes as the vinegar is flowing until you see all holes flowing vinegar.
Chunks of trash will dislodge in your heater tank and flow to your spray head, so keep that toothbrush ready.
Do this at least 5 times, then allow the Coffee maker to sit 30 minutes with the heater on to finish dissolving the lime and calcium deposits in the tank.
After 30 minutes start flushing the system with clean water to rinse out all of the vinegar, or until you can no longer smell vinegar in the coffee can.
Good Luck!
Mar 04, 2010 | Bunn VPR Coffee Maker
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Does not brew a full pot of coffee
1) Unplug the NHB
27) Empty pot.
Oct 29, 2007 | Bunn NHB Coffee Maker
Bunn VPR Coffee Maker Logo
274 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
