Walthe universal remote control
I have a Waltham universal control it is silver, the Tv, VCR etc buttons are the opposite end to sensor there are 8 of these next are thr 4 coloured buttons then 4 grey buttons , 2 large blue oblong buttons, all the middle buttons are yellow, there is no model no, I can if you have an email address send a picture, I need instructions to set it up, can you help please
  • roleymole1 Jan 20, 2009
    I also have the same problem with this remote i am trying to link it to my goodmans tv some one please help!!
i have the same remote....no instructions..please help
thanks
Posted on Nov 25, 2008
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
How to setup phillips universal remote to a panasonic tv
More items...
Nov 29, 2016 | Panasonic Televison & Video
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
SILVER RC24922-C LOST CODES FOR TV AND DVD
Most universal remotes will drop the code memory if the batteries have been out for more than 1 minute - you will need your instruction sheet to reprogram, this will have the codes too.
If you have lost the sheet then google the remote model number
Mar 19, 2010 | Universal Remote Control GE174Universal...
Remote won't communicate with television
The sensor for these Panasonic tvs along with certain Toshiba models tend to have the problem with the sets sensor going out. But if you are using a universal remote because you do not have the original, then most likely you will need to use the vcr control codes to program the tv. but if the original doesnt work either. your insticts are probably right. There is one last trick if you do have the original remote that u can try. I've had this work for me several times on service calls. With the batteries removed. Press every single button on the remote once. make sure you do this nice and slow making sure you are pressing the button down . if its a toggle button or rocker button like most volume or channel up down buttons(meanning that physically the is one button but depending on what part of button you press it does something differemt) well treat these as seperate buttons. Also if the remote has any switches on it. Like vcr/tv switch or vcr 1 vcr 2 etc. Then switch to other position and repeat the process of pressing all buttons once again. (remote does not have too be pointed at tv for obvious reasons) Now replace the batteries and have fingers crossed. Good luck.
Mar 11, 2009 | Panasonic AG-520G 20" TV/VCR
I need the code to program the philips universal remote to a sylvania tv
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Need VCR codes for Magnavox Universal remote model CL034
Nov 26, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
Electro Med Services...
