Question about Nikon CoolScan V ED Film Scanner
Yellow color cast to scanned slides
My Nikon CoolScan V film scanner has begun producing scans of slides with an overwhelmingly yellow color cast. This persists even when I ramp up the blue in the tool box before scanning.
  • suza1 Oct 30, 2008
    Problem solved! The scanner appears to have spontaneously repaired itself. I just tested it on some color film negatives. These turned out fine. I then scanned some slides, including the original ones that came out yellow, and those turned out normal as well.
    I'm glad I learned about FixYa. I hope Darklord1 didn't go to any trouble yet on my behalf. If he did, thanks! --suza1
  • ERIC Mar 07, 2012
    I am seeing the same problem. Coolscan V with latest software, new driver to use on Windows 7 x64. Works great with negatives, but positive slides were totally yellow. I don't know how I fixed it but kept turning stuff on and off including the Nikon color management, kept restarting the program and resetting the unit unit bam! all good. Scanned many slides, then shut down, next time turned on same problem, same solution. Makes no sense but I got my slides scanned, glad it's done now..
  • 2,427 Answers
Nah i didnt get into any trouble,, feel free to use us anytime!!! I'm happy the scanner worked if you need any more help you know how to find us..Next time that happens with the scanner try unplugging it restart the system and then plug it back in.. :)
Posted on Oct 31, 2008
It's been several years since I used my Coolscan IV, so I've updated the drivers, got it talking to the computer, imported the image into Photoshop CS2. The image colors are way off, red is green, another slide has a blue cast, etc. I've turned the scanner off and on several times, reloaded the drivers, played with the settings, etc. What else can I do?
Sharon
Posted on Sep 15, 2009
When I scan transparencies, 1) The transparency to be scanned doesn't seem to lock itself into the MA-21 slide mount adapter the way it used to. I looked inside the adapter and everything seemed to be
I have four Nikons we use for commercial scanning. As you've seen the MA21 is a simple device that can hardly fail. There are two prongs that hold the slide down against the metal slider that after scanning ejects the slide. If you pull the MA21 out and put a slide in you can see if there is any undue play. Even if the prongs have worked loose an upright unit should function fairly well. I would suggest the cause of your issue is elsewhere and we've had this from time to time. I would change the USB port the scanner is connected to, maybe swap the cable too, reset / restart the scanner and (from my experience) the problem at some point will go away.
Mar 11, 2014 | Nikon CoolScan V ED Film Scanner
Edge Of Scan Overexposed
If the slides are ok , and not overexposed themself, brown discoloration on the side means a problem with the scanner lamp.
Oct 05, 2008 | Nikon CoolScan V ED Film Scanner
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
During slide scanning, after performing auto focus and auto exposure, get error message "there was an error in performing a post processing" any suggestions? using Nikon cool scan v ed
First suggestion would be to connect scanner to another PC to see if the problem persists. Might also help to try to scan with alternative material (mix if slides and negatives) to narrow down where the issue lies. You could also play with features such as Digital ICE on and off. I'm afraid if none of these produce a functioning scanner you will need to contact Nikon to arrange a repair. There is really nothing the typical user can do to fix these machines at home.
Oct 13, 2013 | Nikon CoolScan V ED Film Scanner
After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Launch Nikon Coolscan, but browser/scanner window doesn't open
I think the scanner may have got confused and be expecting another adaptor to be connected. If you slot in the single slide adaptor, wait until all the scan functions become active on-screen, then remove that and insert the SF-210, you might find it works OK.
Jeff Underwood 1scan.co.uk
Nov 16, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Problems with batch scans and with filing using a non-Nikon code system
Did you try saving your choice of settings as user settings ? That way, they will serve as defaults for all subsequent scans.
Jul 21, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon 8000 film scanner problem
I If you use nikon scan you get a different error warning Update nikon scan and also gdiplus.ddll update from thre nikon web site. It worked for me.
Jul 04, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Trouble ejecting slide from SF200 nikon coolscan 4000 ed
open the case of the scanner, and check to make sure that the ejection mechanism is not malfunctioning, or jammed someway.  If this is not the problem, try using thinner slides as thicker ones could also cause this.  If all else fails try un plugging the scanner for a few minutes, and try again.
Jan 10, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon CoolScan V ED Film Scanner Logo
512 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
