Question about HP Pavilion dv4000 Notebook
Document viewer.msi Every time I reboot WinXP Documentveiwer.msi appears and wants a CD to fix. I am not sure what CD to use.
  • 71 Answers
You will need Microsoft Office CD to repair it.
Posted on Nov 02, 2008
There is a PC made by myself ,it is included MSI482M-IL. Now it is W2K. I want to install W-XP. I tried install that,but I can't. Becuase always PC set up W2K. I can't boot control in this BIOS. How...
go to bios setting first, then at boot device select boot from cd at first, then press f10 to save then enter, pc will reboot, insert winxp cd then press any key at "press any key to boot from cd" appear then follow instruction that shown after that
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | MSI RS482M-IL (7145060RS482MIL)...
When opening hp photosmart premier 6.5 message comes up document viewer msi,the feature you are trying to open is on a network that is unavailable.
What that means is that when you try to run the program, HP Photosmart, that program, in order to do what you ask, must install a "Feature", or something "It" needs, now the place or location & File, it is looking for it, on a network location, maybe, somewhere, on the internet, well it cannot "Find" the place nor the File. That file is called Document Viewer.msi, this is an Installable program, so if you download and install it will NOT have to look for it. I include a download link for you. Down load and install by double clicking the .msi file. software.informer.com/getfree-documentviewer.msi-7.0-hp-download
Also look here HP explanation. http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1261587385981+28353475&threadId=1086024
Mar 02, 2010 | HP Pavilion dv4000 Notebook
MSI K8MM-V motherboard doesn't work after BIOS update
First of all never update or install the new bios.. plz let it be geniune .. another thing is that you have to now do the following which might help.. not sure but should
  1. Open the case
  2. look for the jumper on the mother board.
  3. when found take it out
  4. and the reboot or boot your machine
  5. then check if bios options and windows have started
  6. if windows does not appear then install new OS recommended windows 7.
  7. after this plug the jumper back into the motherboard back.
Now this won't work then it can posibly have damaged you motherboard...
Jun 23, 2009 | MSI K8MM-V Motherboard
Hp Printer CD ROM Problem
Unfortunately, this is a frustrating and widely reported issue. Apparantly the HP software is not compatible with Office.
If you have reinstalled the document viewer.msi file from your cd repeated times and you keep getting popups indicating its failure, you will need to uninstall the document viewer.
Here are the instrucitons, courtesy of Jasdev Singh:
">> If you have installed any all-in-one printer driver software then put the disc in
else follow Step 2:
Step 1:
>> Put the printer disc in and goto Setup folder and search for Document viewer folder.
You will find two files under that. Double click on DocumentViewer.msi and install that. if you right click you will get repair also.
Step 2:
>> if you dont have any disc then goto Control panel and select Add/Remove Program.
>> Remove DocumentViewer entry. "
If you can't uninstall from Add/Remove programs or don't find an entry for the document viewer there, go to this link and download the Windows Installer Clean Up utility Download, Install, and Run this application...
>> I am sure you can select DocumentViewer now and hit Remove button.
This will clear DocumentViewer from you computer."
Please also refer to this KB article for additional information about clearing your temp files, etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hye...
You do not require a driver to install operating system
1) set BIOS to boot from cd
reboot and insert operating system cd once inserted it may not find it reboot it will load all info about machine at the end you should see
2) press any key to boot from cd Press a key usually spacebar
3) the operating system should start to install
4) read all instructions as you go
when Operating system has fully installed it will reboot
5) Do NOT press any key on computer rebooting as you will go through the whole process again which is a no no
Jul 25, 2008 | MSI MS-6533EG-LM (MS-6533E-120)...
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Document viewer msi
This problem is easy to solve. Just insert the installation CD that came with your HP printer into your computer when prompted to insert a CD. The file will be downloaded automatically.
Jan 17, 2008 | HP Pavilion dv4000 Notebook
Computer
1st make a backup of all the data you want saving.
2. find out your recovery cd or operating system cd.
3. insert the cd and then reboot.
4. on the start up key the first screen you see about 3 secs after turing back on hit the hot key.
could be F2 or F8 depends on your mother board.
if its neither of these watch carefully on the startup screen it should tell you wich key it is but be quick cause it will only be up for about 2 secsa :-)
when the cd boots up just follow the instructions.
please rate my solution on how it helped you.
any more quiestions or if u get stuck just reply to this post.
Dec 16, 2007 | Intel Motherboard
NO Sound - 865PE Neo2-PFS Platinum Edition
You need to install the correct version of the sound drivers from the MSI website under your motherboard type. Third party or from Realtek sound drivers won't make you sound chip works. If after installing sound drivers from MSI website still don't work then your on board sound chip colud be defective.
Jun 29, 2007 | Abit AS8 Motherboard
HP Pavilion dv4000 Notebook Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
