Question about Refrigerators
Mini husky fridge smells fishy when walk in room and yellowy foamy stuff but hard coming out of crack at the back.
5 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Fridge Smell
Wash it out with bleach. Nearly always solves this problem.
Posted on Aug 02, 2007
xMadx
  • 64 Answers
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Posted on Feb 04, 2008
  • 148 Answers
SOURCE: fan blows out a smell from underneath fridge could it be leaking gas.
call the repairman back and say forget it ,on the motor youll see a flat pan ,like a cookie sheet on top ,the excess water from the freezer drains into a tube and into that pan as the motor gets hot it evaporates the water,just clean the pan,shut down fridge,unplug and let motor cool,clean the pan and tell hubby not to waste good beer lol
Posted on Jul 07, 2008
I have the same problem with the odor. I took the back off and discovered the drip pan was full of stagnant dirty water. This place is bacteria heaven. The problem I have now is that i cant seem to find a way to remove the pan without taking the motor out and everything. Any suggestions?
Roman
Posted on Jul 27, 2008
techjuli
  • 157 Answers
SOURCE: Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Posted on Dec 01, 2008
We have got a hotpoint future fridge and we have
after you have cleaned the refrigerator, place a small bag of open charcoal in the freezer section and refrigerator section until the smell goes away.
Jul 24, 2010 | Hotpoint HSS25GFP Side by Side...
A fishy smell coming from fridge
if its onb the back wall in the upper right corner 1/2 turn then pull down
if in the toe kick
1/2 turn then pull straight out
then push lock and light for 5 secs to clear change lite
Oct 08, 2009 | Jenn-Air JCD2389G Side by Side...
Fishy smell in camper fridge
They freon used is mainly amonia,best thing to use is bleach put in spray bottle mix 70 percent water and 30 percent bleach squirt entire fridge let soak then wipe clean let air out as much as possible!!!! :)
Jul 19, 2009 | Zanussi ZEBF277W Bottom Freezer...
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan blows out a smell from underneath fridge could it be leaking gas.
Apr 30, 2008 | Frigidaire FRT18B4A Top Freezer...
Feb 04, 2008 | Maytag MBB1956GES Bottom Freezer...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
