Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectra III typewriter
My typewriter (above) ribbon is being chewed by the typewriter. I think maybe it is sticking to the correction ribbon. Any ideas as to how to stop this?
  • Lexmark Master
  • 3,594 Answers
There are two different ribbons for selectric III T/W's. One has the ribbon guides as part of the cassette the other the guides are part of the machine.
Be sure the ribbon and L/Oare installed properly and the ribbon is winding on the take up spool properly (counter clock wise) and if the guides are in the machine id to the left if thr white slacker finger just L. of the ribbon also be sure the L/O tape is behind the black seperation finger and the ribbon is in front of it (just to the rt. of the opening in the plastic card holder).
DickyO
Posted on Oct 30, 2008
Typewriter repair manual
I just replaced a ribbon in a 3500 IBM wheelrider ribbon with the following product which is supposed to be combatible.
DataProducts Compatible Typewriter Ribbon
Dataproducts Lift Offf Tape Catridge
I had no problem istalling the tapers, forwarded the ribbon as instructed, but when I type no tryping appears on my paper.
Aug 22, 2014 | IBM Typewriter Wheelwriter III 3 with 2...
What would cause the ribbon guide to not lift to ball strike position?
Check ribbon adjustment there is an adjustment lever that adjusts the ribbon up and down.Also check that the ribbon is still good not wore out,out of ink.
Jun 27, 2014 | IBM Correcting Selectric III Electric...
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
DickyO
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
Selectric III typewriter
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
HAVING TROUBLE PROPERLY CHANGING A CORRECTABLE RIBBON IN AN IBM SELECTRA 111 TYPEWRITER
Go to lexmark.com , click yuor way to publications there you will find an operators manual. The pictures and descriptions are better than mine. (Be sure you have the right ribbon Selectric III takes two different ribbons)
DickyO
Sep 23, 2009 | IBM Office Equipment & Supplies
I need to know how to install a ribbon on an IBM Selectric III typewriter.
Go to lexmark.com and click your way to publications there you can get instructions and pictures of installation. Remember there are 2 different ribbons for Selectric III,s.
DickyO
Sep 19, 2009 | IBM Office Equipment & Supplies
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
189 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
