Question about LG LRTN19320 Top Freezer Refrigerator
My fridge makes loud popping noises and is over cold (freezing the things in the fridge & frosting up the freezer, when it is a frost free freezer)
  • 2 more comments
  • etc716 Jan 18, 2008
    I don't have the noise problem and my freezer side works properly and is frost-free, however, my refrigerator side recently started freezing solid items that seem to be located near the door on all levels. The items in the rear portion of the fridge do not freeze. The factory setting for the thermostat is 4, I have ours on 2 and the products are still freezing.
  • Anonymous Mar 13, 2014
    Fridge and freezer not cold enough, and frost build-up on frost-free freezer inside- what is wrong?
  • Anonymous Mar 17, 2014
    FREEZER COMPARTMENT NOT DEFROSTING
  • Anonymous Mar 20, 2014
    makes a loud popping sound sometimes freezer is fine its a Samsung side x side
  • 237 Answers
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Posted on Dec 23, 2006
Buy a new one that always woks
Posted on Mar 28, 2008
4 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Refrigerator
It may well be the defrost control. They have a turn slot to advance them if the timer quits. You need a little aptitude to find this and check it. If you think you can do it let me know, and I will walk you through it.
Posted on Dec 26, 2007
SOURCE: lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Posted on Jan 30, 2009
baraquielnar
  • 247 Answers
SOURCE: Refrigerator is making a loud buzzing sound in the
check your evaporator fan maybe the fan blade hitting edges or the shaft or bushing has damage cause of buzzing sounds apply lubrication or replace bushing but before you dismantle try to off the unit.
Posted on Feb 20, 2011
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Freezer is not freezing its cold like the fridge but thats it. tha fridge is running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser won't shut off nor will the ice dispenser motor
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
LG LRTN19320 Top Freezer Refrigerator Logo
3,169 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
