I would like my sky remote control rev8 to operate my funai tv lcd -b2706 but i just cannot find the right code
  • riesutux Mar 23, 2009
    i can't find code to activate sky remote on for this tv
Try this worked on mine
Press tv on sky remote, cover the lens with your hand. Then press select and the red key together until you see the led flash twice, then type in 678 on the remote
Posted on Apr 28, 2010
BUSH TV LE-40GCL-A-W REV8 CODE REQUIRED
Put the TV and Sky box on, and put the telly on the Sky channel. Press Interactive on the Sky remote. Choose "Program my remote" from the menu list. Follow the onscreen guide. The pages take a bit to update so be patient
Sep 06, 2014 | Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Need code compatible with sky plus remote
Funai- - I am a sky agent & have the codes for all makes and models of tv's - However you have already recived the code that would be used for your tv '0179' / it could be that you are programimg the remote wrong if this is not the case - I can tell you that because of skys changing thier manufactors of thier boxies & remotes that Not all remotes will acceppt the code or programing and unless you are willing to buy every remote new & old to find the one that will I'm afarid you're stuck with the remote for the tv-
however you can sometimes get comi-remotes that will work all your appl.-tv,dvd,video&sky+.
but check with the dealer to make sure before you buy or have it that if it dose'nt work you can bring it back.
I can do a search myself for a make but it will take a few days to get some feedback from my surplliers.P
Aug 18, 2009 | Funai LCD-27 TV
Sky code - LG 47" TV Model Code47LG5020ZB
If there is no code, then there is no code.
The only other option would be to buy a 3rd party remote that is compatible with both devices. Unfortunately there is no way to know if it will actually work until you try it.
Jun 03, 2009 | LG 47LG50 47 in. LCD HDTV
I had the same problem but eventually solved it
I fixed the problem I had with Sky remote control not working with my new TV Model 32LG3000 but I had to update my remote to a (rev8) as the code did not work with my old remote which was a (rev4) the code was 0056
Jan 10, 2009 | LG 42LC2D 42 in. LCD HDTV
SKY REMOTE CODE
Code is 0206. Good Luck!
Jul 26, 2008 | Televison & Video
Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Mar 20, 2008 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
