Question about AMC Multimedia 3050a 2-Channel Amplifier
No sound through my AMC 3050A
I've recently moved my amp to a different location, and after the move I get absolute silence out of it. I tried using a few different inputs but I'm afraid something is fried within... The power on button lights up and seems ok, but I get no sound. Do I need to go to a shop? Or is there something I can check? Thanks, Alon
  • Alon Almog Sep 16, 2006
    I have a few updates.
    First of all, I checked the phones output and it works, so the amp itself works fine but the left/right outputs are not working.
    Second, I took the amp to the shop, and the first thing they've chekced are the fuses (there is one fuse near the AC input and two more fuses for speakers output - one for each speaker). All fuses checked out fine.
    The guy at the shop told me that 99.9% of the problems with amps not outputing sound are burnt fuses - so if anybody encounters this problem check your fuses.
    Unfortunatly, all my fuses check out fine, and the problem is still unidentified. My feeling is that there is a problem with the switching circuit that switches between phones and the speakers. This circuit has a relay built into it which is usually regarded as a less reliable component in electronics (as it has a mechanical moving part inside it).
    The guy at the shop also told me that malfunctions with AMC amps are so rare, that he'll fix it within warranty (even though warranty has expired 6 months ago).
    Hope this helps anybody else out there.
    Alon Almog
Hi, I took the device to the store I brought it from, the technician was amazed that the AMC was broken. Apparently, it is one of the more reliable deviced around. He has checked the fuses and he was again amazed that they checked out OK. He ended up replacing the main board and it works fine now (naturally).
Posted on Aug 26, 2007
    Novelist:
    Champion:
  • 275 Answers
Strange problem. If you have moved the equipment carefully, reconnected all cables and inputs properly in the right sockets and terminals, i don't see any reason why the amplifioer should not work. And if Power is Ok, Amp should work. Pls recheck all connections properly once again.
Posted on Sep 15, 2006
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Extreme differences on overdrive channel
Please, take it to a tech in your area, or look for a good one to ship it to. An 2007 amp is not old at all.
Jul 24, 2017 | Marshall Mg100dfx 100-Watt Combo Guitar...
My tuner will not work! I've had this unit for 4 years & it's always worked perfectly. Then yesterday, the tuner stopped working. "Tuning" flashes on-screen intermittently & no...
1. Verify the source of the signal - Look for any antennas that may have been hooked up, and verify connection has not been moved or removed.
2. Test with a different output by plugging in some headphones, and recheck the volume through the headphones.
3. Check that the A/B switch for the speakers has not been moved, and that they are switched to the correct speakers.
4. Try AM and FM for any signals both with speakers and then headphones.
Bruce
May 05, 2011 | Audio Players & Recorders
My amc 3050a over heats then the fuse blows, this has just started happening does anyone know what might be causing this?
this may be due to the fault that the output is overheating and exceeding the currrent limit set on the fuse . Hence the fuse is blowing off. If the amp is working normal after it coold off and after replacement of the fuse, then the overloading of the output needs to be checked.check the rating of the speakers. Do not use the amp inside a closed cabinet. If possible use a good ventillation , a fan and try out if the amp works fine. If so check if the soruce is producing any distortions to thermally run the outputs. reduce volume level , and check the heating. once you have located the problem of the heat proceed to isolate the section. helpful? Good day
Jul 13, 2010 | AMC Multimedia 3050a 2-Channel Amplifier
The slide to turn on the phone will not move.
Try using the stylus located bottom right. Use finger nail to flick out. Once you've done this select settings and select pen calibration until Done appears on screen this sets the sensor according to your touch!
All the best.
Aug 12, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Noise coming from the belts I suspect the bearing please help
Belt noise can be silenced with the application of silicone spray to the belt. It won't hurt the belt at all. If it's a bad bearing the silicone spary won't quiet the noise. To locate the bad bearing use a short length of hose or tygon tubing. Watch out for moving parts. Listen in one end and point the opposite end of the hose to different areas/bearings. The noise will be louder when you locate the problem area. The same technique one would use to locate a vacuum leak. Again, watch out for moving parts.
Jun 09, 2009 | 2004 Volkswagen Golf
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Mar 29, 2009 | Elgin 0518709FA
Speaker output very high
You can't control it with the balance control?
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 03, 2017 | AMC Multimedia 3050a 2-Channel Amplifier
AMC Multimedia 3050a 2-Channel Amplifier Logo
418 people viewed this question
Top AMC Multimedia Audio Players & Recorders Experts
 Grubhead
Grubhead
Bilral
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you an AMC Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
