Home | Venta | - Airwasher LW44 Air Purifier | Clean fan area
Venta - Airwasher LW44 Air Purifier
Problem for Venta - Airwasher LW44 Air Purifier
Clean fan area
By eeduranty on Oct 30, 2008
The fan and the area around it has an accumulation of dirt and dust. How do I clean it?
Solution #1
posted on Aug 23, 2009
Not Rated)
Linda Banks
Rank: Master
Rating: 0%, 0 votes
It can be opened from the top and pulled out. easily done. Just click on the tabs by the speed dials. Sounds like you should be using the venta water treatment additive and Venta cleaner. Look at www.ventahumidifiers for help
Was this helpful?
Yes
No
Solution #2
posted on Jul 03, 2009
Not Rated)
rickpepper
Rank: Guide
Rating: 75%, 1 votes
NOTE:It is easier to remove the motor when the upper housing is still sitting on top of the lower housing unit.
  1. Turn the power off by unplugging the unit.
  2. Next to the speed directions buttons there are thumb tabs. Press the thumb tabs so that they pop up and unlock the upper housing flaps. a tumb tab on
  3. The four flaps should then drop down like the peddles of a flower.
  4. Grab the center of the motor and lift straight up, be careful when pulling the power chord.
  5. The motor, fan and gear assembly should not be seperated from the rest of the unit.
This will let you clean with vinegar and water.
Great product. Germany design at its best
Was this helpful?
Yes
No
Popular Solutions for Venta - Airwasher LW44 Air
Questions and Unsolved Problems for Venta - Airwasher LW44 Air
Do you recommend Venta - Airwasher LW44 Air Purifier?
Answer
Answer
cooling on my honeywell wont work
Answer
how i clean the sharper image ionic breezr quadra?
Answer
How do I replace a burned out light on my ionicpro turbo ?
Answer
oreck table top air purifier ''collector cell'' light will not reset ,,,cell is clean and dry,... (More)
Answer
When turned on, I can hear the motor but it won't move the fan part
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta - Airwasher LW44 Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
