Fax line and phone line busy
I have a Epson workforce 600 machine that is hooked into my home phone line. However, recently the phone line displays a "line in use" message. The result is that the line is constantly busy. I thought that I had corrected the problem but it returned later. Please troubleshoot this problem for me
    Genius:
  • 2,120 Answers
The best scenario is that your machine need it's own dedicated phone line.
Posted on Oct 31, 2008
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Feb 07, 2012 | Epson WorkForce 600 All-In-One InkJet...
Do you have to hook the phone wire up to the modem to send faxes on a workforce610?
Yes you do have to have the phone line conected to the workforce to send or recive a fax.
You can get the manual on the link below if you need it.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=130786&prodoid=63084540&category=Products
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Epson WorkForce 600 All-In-One InkJet...
My epson fax machine is hooked to magic jack and every time I try to send a fax, I get: communication error 0404
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Dec 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
Epson Stylus BX300F all-in-one - telephone doesn't ring
You are going to have problems anyway. Fax machines are ANALOG DEVICES and will not work reliably on a DIGITAL phone line.
Jun 12, 2009 | Office Equipment & Supplies
271 people viewed this question
jasbo
jasbo
