Question about Blaupunkt RPD-540
Error message when i put the disk in it shows that it loads and then comes up with an error message E-02 how do i fix this please
0 characters
1 Points
Won't wook
Possibly incompatible..are the disks recorded audio? Or store bought? Disk playervlense may be dirty. Go to best buy.. or wherever and buy a car audio cd cleaning kit. Check the condition of the disk aswell andthey would also sell disk cleaning and polishing kits at best buy..future shop..etc.just ask when u get there
Apr 12, 2014 | Nextar NCD50 Car CD Player
My avic x1r will read dvd,s but not the
does your headunit have a usb if so try and put the cd on a flash drive and try it that way
Jan 09, 2010 | Pioneer AVIC-X1R CD Player
Can't get Naxa MP3 Player to do ANYTHING
I tried to download music through windows media player and it shows the music as being down loaded but the equipment keeps going to recordings when I go to "music mode" and NOTHING comes through the ear buds! Please help
Dec 31, 2008 | Naxa Electronics NX-671 Car CD/ MP3 Player
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Mar 26, 2008 | Clarion DB175MP CD Player
Message of an Error
error 6 means that a disc is loaded upside down.
eject the disk and reload it properly
if that isnt working, your CD player is mal-functioning and you should consult Clarion for help
Mar 12, 2008 | Clarion DXZ845MC CD Player
RFX 8320 shows error-9 when I put a CD in
Your unit requires a new laser pick-up.
Feb 06, 2008 | Rockford Fosgate RFX-8310
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Error 6 on in car stereo
Here is the link to the user manual for your player if you need it; Page 38 of the manual (page 42 of the pdf file) describes the error codes error 6 states "a disk is loaded upside down inside the cd deck and doesnt play properly" Suggested solution is to try the disc the other way up, if this doesn't help then there is most likely a problem with the lens - possibly cured by cleaning, please ask again if you want to try this yourself and we can talk you through it Hope this helps :)
Apr 15, 2007 | Clarion DXZ838RMP CD Player
Error message E-60
First, run a chkdsk (or scandisk) to your Ipod from your computer (like any other hard disk drive on your computer)since it is probable that the Ipod's hard disk drive may contain errors. Then, follow these steps: 1.) Disconnect the Ipod from the KCA-IP500(the Ipod interface) 2.) Press and hold the middle button and the top button at the same time. 3.) The Apple Logo should appear. 4.) Reconnect your Ipod to the KCA-IP500 5.) The head unit should display loading and then respond to the IPOD interface.
Nov 08, 2006 | Kenwood KDC-MP232 CD Player
Blaupunkt RPD-540 Logo
Top Blaupunkt Car Audio Receivers Experts
xxxxxx xxx
Are you a Blaupunkt Car Audio Receiver Expert? Answer questions, earn points and help others
