Question about Proview PV 1456 14 in.CRT Conventional Monitor
Display problem I am having proview 14 inch CRT monitor.From days its brightness decreased.Now it is giving another problem. monotor light shows that signal is getting from cpu.But there will not be any display on the screen.when monotor is shaked for some time then there will be display. Other monitors are working well with the system.could anyone say solution to my problem
How we can solve the display problem
Posted on Jul 03, 2009
  • 4 Answers
I would also like help with this same problem. Hitting it used to work but now it does nothing.
Posted on Jan 21, 2007
  • 105 Answers
Probably a bad solder connection on the mail board.
Posted on Sep 13, 2006
My LG 700E crt monitor has stop functining to control brightness and contrast ,Any other way to increase or decrease brightness and contrast. pls let me know thanks
It's time to RESPONSIBLY RECYCLE any 17-inch CRT monitor, and buy a LCD monitor;
used LCD monitors can be purchased for under $50.
It would cost you over $50 to take the CRT to a TV/Video repair shop, for trouble-shooting and repair.
May 11, 2011 | LG Studioworks 700S 17" CRT Monitor
My screen size is reduced not any problem but when i use the keys on monitor they instead of widing or giving the normal screen size it became 1 inch shorter now i need some help with my moniter it looks...
Try holding the control button down on your keyboard and while holding it down, use the scroll wheel on your mouse and rotate it slowly one way or the other. This will increase the size of your screen (or decrease it depending on which way you turn the wheel).
Jan 29, 2018 | Philips Standard 104S 14" cRT Monitor
Sir iave an IBM desktop and the monitor windows
Press Fn+F5 to decrease brigtness Fn+F6 to increase brightness
Try this please.
Jul 05, 2010 | IBM E74 17" CRT Monitor
Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Oct 02, 2009 | Proview PL19Wb Monitor
Gateway FPD 1730 Monitor
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
Jul 10, 2009 | Gateway FPD1775W Monitor
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Dell FP1504 Displaying very dark " Ithink this is backlight issue
If you are not a technician you can´t solve this problem because are to desasembly your device and check the Q7 and Q8 and C5 that components are on bad conditions and need to be replaced,I told you because i repaired one of these monitors for the same problem
May 08, 2009 | Dell UltraSharp 1504FP Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor trouble_screen display
Sorry Guys, I have the same problem on my monitor. I am going to repair it. Later I will give you info what might it happen.
cheers,
doods
Mar 20, 2008 | AOC 4 Vn 14" CRT Monitor
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Proview PV 1456 14 in.CRT Conventional Monitor Logo
448 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
